A forum search for PC Oscilloscope returns several suitable suggestions.I need a gadget for converting PC into an oscilascope. (full function)What may be the cost ?. If any chance of getting a circuit is well & good.
I need a small interface gadget which can be pluged in with USB port , Min 100Mhz , with dual trace with all function.the front panel selector switches Amphenol connector all will be required with the kit all probes are supplied , light weight stuff.Instead of occupying huge space it will be simple it can be used with lap top.somebody commented I feel bad my carrier start with oscilascope, I can calibrate trouble shoot oscilascopes.I worked in a prestijeous company.That's kind of a broad question. What do you consider a full function oscilloscope? What are your intended applications?
There is a freeware app called winscope you might check out.
