PC fan connected to wall adapter causing lights to flicker
MisterBill2
Joined Jan 23, 2018
28,212
I have had to repair installations in which that removable jumper strip between the two outlets in a duplex outlet had cracked at one of the separation crimps. Quite a subtle source of problem. (folks in the UK will not know about this, UK pout;ets are totally different.) That fault mode can cause very strange problems in outlets not in the same area, and be a real puzzle to track.
