MrSoftware
- Joined Oct 29, 2013
- 2,274
I would think that should be fine too. Just don't leave extra cable hanging off the end. Worst case you can terminate the ends with 50ohm or other smallish resistors and drive it with mosfets or other high current source. The termination should kill any noise, though i don't think it will be necessary. Actually for 50hz you can probably use much larger resistors.
