Thank you for these helpful replies! Yeah, I do know what you mean--I should have thought of that! Guess this is my first time trying to repair something like this. I've got plenty of solid-copper wire around so I'll just take some of that and run it to the next pad. I should have a chance to try that tonight. I'll post back with the results....... Thanks people!Don't worry, this happens sometimes.
What appears to be copper probably isn't. If this was a green masked PCB then you need to follow where the trace went and if needed you can scrap off some green mask and solder thin jumper wire's to make connections. Or you can follow the
trace to the next pad and connect there.
If I'm making no sense, then why not post a clear picture of the area in question.
The tape monitor allows you to get the pre amp output points. Hook to another amp and see if you have a signal there.Update: OKAY! I got in there and soldered up some wires to the pins and viola, it works!
Or at least the right channel works now. I tested it on FM, AM, & aux, none have any output on the left channel. And the VU meter for the left never moves except when you turn the unit on. The right one goes from min to max depending on the radio station strength. Any ideas what I should check next to see where my problem might be? I might post up some more detailed pictures of the insides this weekend.
Excellent diagnostic advice... will do this weekend.The tape monitor allows you to get the pre amp output points. Hook to another amp and see if you have a signal there.
I've got dozens of them still. I also have an Akai CR-81D 8-track recording deck that still works.I don't have any 8-tracks to test out the player, but maybe I might get on eBay and pick some up soon.
I did an output amplifier on a Marantz receiver once and I had to also replace the power transformer and then redo the power supply. So while it can be done it can be a very big project. So my suggestion is to locate a separate power amplifier able to provide however much power that you want. And since all of the controls are on this receiver, all that the additional amplifier really needs is a power switch, although a level control can be handy. You may even be able to use one of those high powered car amps, substituting a mains powered DC supply for the inverter supply inside the unit. Those amps generally have much better specifications. 0.9% distortion is not great for most listening you can do a lot better.-noted! I ordered the STK040 replacement off eBay today. Only $10 but it's coming from China so it'll be a week or more before I see it probably. I'll update this thread when I get the chance to install. Might be a while, but hopefully this does the trick! Thanks everybody.
This is an ancient thread and the TS solved his problem way back then. It was recently revived, and now with a different problem.I did an output amplifier on a Marantz receiver once and I had to also replace the power transformer and then redo the power supply. So while it can be done it can be a very big project. So my suggestion is to locate a separate power amplifier able to provide however much power that you want. And since all of the controls are on this receiver, all that the additional amplifier really needs is a power switch, although a level control can be handy. You may even be able to use one of those high powered car amps, substituting a mains powered DC supply for the inverter supply inside the unit. Those amps generally have much better specifications. 0.9% distortion is not great for most listening you can do a lot better.
OK, thanks for the notification. Nothing popped up like it used to pop up when I would go to address an old thread. So I guess the problem is somebody needs a power transformer. If they have the failed one, one very tedious option is to count turns on the low voltage windings, presuming that the pilot lights are 6 volts. The voltage ratio should be close to the turns ratio.This is an ancient thread and the TS solved his problem way back then. It was recently revived, and now with a different problem.
I think you only get the big warning when you're the one resurrecting an old thread. If you're the second one in, it just looks like any other thread. This has been an issue here for as long as I can remember. If you don't look at the dates, you read and read to get caught up and then try to write a useful post, only to discover the world has moved on long ago.OK, thanks for the notification. Nothing popped up like it used to pop up when I would go to address an old thread.
Probably the 65 volt winding is the high current one for the output stages and the 24 volt one provides power for the rest of the electronics and the tape drive. And the 5.1 volts would be for the lights.@Lonramsingh Here's a schematic of a transformer I took out of an old stereo. It had an STK4192 amplifier chip in it. I have it in my cabinet for if ever I need any of these voltages. I'm going to guess yours is probably similar in voltages. Depending on your power, these values will possibly change.
| J | Panasonic RE 6137 as Guitar Amplifier with Preamplifier | General Electronics Chat | 19 | |
Toyota Corolla Panasonic radio dead after OBD scanner connection – backlight works, no boot | Technical Repair | 0 |
