- Joined Jul 18, 2013
- 30,757
Nothing seems to come up with that number, but the O/L's are usually easily visible at the bottom of the contactor.
LmaoI thought it was a pic of a nuclear reactor. Lol.
Wrong version/model?So maxheadroom. The old relay works when you hold the on button and the crane works. If I remove the old unit and put a new one on the crane will not work. Why?
That appears to be the contactor coil, AC versions generally run hotter than their DC counterparts.My thermal camera is picking up alot of heat on right side
It is the one activated by onIs the contactor in the thermal image photo the one that is actuated when the on button is pressed ? If so then this is the one we are interested in.
Les.
I did order separately and made sure to match flaBTW, if the new contactor you used as a replacement is a same/similar type that uses thermal O/L's, the contactor is usually supplied without them and they are obtained separately in order to get the right sizing.
i.e. current rating = 1.5x motor FLA.
The current DIN style of contactors are quite a bit smaller and the O/L's are adjustable electronic.I did order separately and made sure to match fla
