Ouch.
Ya’akov
Joined Jan 27, 2019
10,235
This morning, preparing breakfast, I cut about 2mm off the tip of my thumb, about 10mm at the widest point.
Trip to the ER, bleeding stopped. It hurts. I will probably have an ugly fingertip permanently.
I must say, it's a psychological setback to an extent I wouldn't have expected. Oh well.
MaxHeadRoom
Joined Jul 18, 2013
30,658
As a prime user in the kitchen, I always try and ensure all knives are kept sharp, use the steel on them at least once a week, if not more.
Less dangerous that way.;)
Max.
Ya’akov
Joined Jan 27, 2019
10,235
I have been preparing food with chef's knives for decades. This was an error, not ignorance. I've never gotten a serious cut in thousands of meals.
jpanhalt
Joined Jan 18, 2008
11,087
I watched Julia Child's French Chef on WGBH (Boston Public TV) religiously. Her Bouillabaisse was one of the funniest episodes (http://openvault.wgbh.org/catalog/V_FCE3AFA560C24607BBB137BED1CFE183). She chopped as shown resting the chef's knife against the knuckles. She was almost as fast as an electric food processor. I have never come even close.
In a very late episode she had an assistant or student as she was getting quite along in age. He was chopping something and was right handed, then the show cut to commercial. Upon return, his left hand had a bandage. My guess is he wasn't quite as skilled as she was and tried to go too fast. Funny, but ouch.
wayneh
Joined Sep 9, 2010
18,104
Not relevant here but I've enacted a rule in my kitchen that the wine or cocktails are not served until the bulk of the cutting is done. The rule gets bent but knowing that a safety rule is being bent reminds one to use greater caution. I do believe the accident rate has gone down. And yeah, sharp knives are a lot safer than dull knives. You may still get cut but the forces involved are lower.
Berzerker
Joined Jul 29, 2018
624
Sorry to hear that Yaakov
As a kid around 9 I cut my right pointing finger nail in half right down the middle. Cut all the way up to the first knuckle and could see the bone inside. Can't put stitches in a finger nail.
narkeleptk
Joined Mar 11, 2019
586
I've lost my fair share of meat chunks out of fingers so I can confidently say you'll be fine. I once had this high speed cutting blade in the image below slice a good portion of my pointer fingers knuckle off. I washed it out with alcohol and wrapped it up for awhile. Healed up just fine, just a tiny scar there now. I wouldn't think about it at all other then making sure it doesn't get infected.
WBahn
Joined Mar 31, 2012
32,829
It may not be as ugly as you're imagining right now. When I was about 12 I picked up a roll of steel wool (use for floor polishers) and it immediately dropped because it sliced the tip of either my index or middle finger clean off -- guessing a thickness of two or three millimeters. Bled like the dickens, but just applied lots of pressure till it stopped and wrapped it with a bandage. Amazingly, I can't even tell for sure which hand it was (pretty sure it was my right, but that's over forty years ago and the memory's not what it once was), let alone which finger. I've got a couple other small scars that took decades to disappear but are now gone -- or that I can only make out from time to time (but, then again, the eyes aren't what they used to be, either).
Hopefully it wasn't as bad as Julia's cut this time:
cmartinez
Joined Jan 17, 2007
8,760
You should see my own fingers, they're full of scars and distorted fingerprints here and there... dating back to a time in which I tried to learn wood carving using a pocket knife... in the end, I didn't learn much about that particular art, but I learned a lot about first aid...
Glad to hear your incident was not too serious...
atferrari
Joined Jan 6, 2004
5,011
I eat mostly steam cooked vegetables every night.
Cutting is not in juliana but cubes. Do it every three or four days when coming with the fresh buy from the greengrocer. After washing and drying, I do the chopping in one session when I still feel not tired. Learnt that the less dangerous are not only the sharper but the bigger knives.
Later, tired or not, I just select what goes into the cooker.
BTW I never considered that mezzaluna but I feel too much for veggies only.
G Homework Help 11
Similar threads
ouch
