Indeed. Trying to get there.Has the thought occurred to you that the buffer resetting might actually solve your problem? Putting it off until later might prevent you from finding an easy solution?
Hi D,Has the thought occurred to you that the buffer resetting might actually solve your problem? Putting it off until later might prevent you from finding an easy solution?
Hi JT,Can you post the old program that had the radio working? A look at it may be helpful.
Agreed that we can wait on more changes until you drill down into the radio error.
I asked the question about a delay between radio messages because if you change a channel when the data stream is active, that can generate UART errors. With the working channels at 5/sec, there is a good possibility that you are lucky enough to hit between messages most of the time. If there is little or no delay between the messages, the chances of jumping into the middle of a message increase and with that the probability of mis-handled errors increases too.
Hi JT,I’ll take a peek.
Can you also post a link to your current schematic or just repost it here? Both ends.
Hi JT,Both ends means both ends of the radio link. I think I need to review your project in detail. My misunderstandings are causing confusion.
'18LF4620 8MHz XTL BASE PCB_4 INT_PAR REMOTE only 300620 0900
Define CONFIG1L = 0x00
Define CONFIG1H = 0x02 '0x02 =EXT 8MHz
Define CONFIG2L = 0x1e
Define CONFIG2H = 0x00
Define CONFIG3L = 0x00
Define CONFIG3H = 0x81 'Set for HVP
Define CONFIG4L = 0x80
Define CONFIG4H = 0x00
Define CONFIG5L = 0x0f
Define CONFIG5H = 0xc0
Define CONFIG6L = 0x0f
Define CONFIG6H = 0xe0
Define CONFIG7L = 0x0f
Define CONFIG7H = 0x40
Define SIMULATION_WAITMS_VALUE = 1 'Comment in for SIM out for PIC
Define CLOCK_FREQUENCY = 8
Define SINGLE_DECIMAL_PLACES = 2
Define STRING_MAX_LENGTH = 40
'SET PIN IN/OUT
TRISA = %00000000
TRISB = %00000000
TRISC = %10000000 '7 = RX
TRISD = %00000000
TRISE = %00000000
'SET BITS ON/OFF
PORTA = %00000000 'ON/OFF
PORTB = %00000000
LATB = 0
PORTC = %00000000
PORTD = %00000000
PORTE = %00000000 'POSS MCLR RE3
WaitMs 10
'set up interrupts
RCON.IPEN = 1 '%10000000 Int Priority Enable bit 'This MUST be included when using Interrupts (Priority HIGH/LOW)[#189 hserin blocking]
PIE1.RCIE = 1 '%00100000 EUSART Receive Interrupt Enable bit [ 1=en ]
INTCON.PEIE = 1 '%01000000 Peripheral Interrupt Enable bit
INTCON.GIE = 1 '%10000000 Global Interrupt Enable bit
''BAUDCON.BRG16 = 1 '%00001000 1 = 16-bit Baud Rate Generator – SPBRGH and SPBRG
TXSTA.SYNC = 0 '%00010000 = Asynchronous mode
RCSTA.SPEN = 1 '%10000000 1 = Serial port enabled (configures RX/DT and TX/CK pins as serial port pins)
RCSTA.RX9 = 0 '%01000000 0 = Selects 8-bit reception
RCSTA.CREN = 1 '%00010000 1 = Enables receiver
'Read the 8-bit received data by reading the RCREG register.
'If any error occurred, clear the error by clearing Enable Bit, CREN.
'If using interrupts, ensure that the GIE And PEIE bits in the INTCON register(INTCON < 7: 6 >)
Symbol yled = LATE.1
Symbol rled = LATE.2
'START UP LEDS
yled = 1
rled = 1
WaitMs 1000
yled = 0
rled = 0
WaitMs 1000
'**** Setup Hw USART ****
Hseropen 9600
Hserout "READY", CrLf
Dim char As Byte
Dim buf(50) As Byte '*** received message comes to buf
Dim rxin As Byte 'ïndex To buf
''Dim cnt As Byte
Dim msg_rdy As Bit
Dim err As Bit 'Errors in receiving $DATA
'GPS and REMOTE
Dim strchr As String 'GPGGA or $REMOTE msg
Dim sinlat As Single 'For calculation
Dim sinlong As Single 'For calculation
Dim strtim As String
Dim strlat As String
Dim strlong As String
Dim cnt As Byte 'CHARs counted through buf
Dim strbuf As String
Dim buf_fill As Bit 'Message loading
Dim buf_done As Bit 'Buffer $ to W 1 = Done 0 = Not
Dim prs_fill As Bit
Dim prs_done As Bit 'Empty Buffer now, it has been READ. as 1 = Don
Dim rxpsn As Byte
Dim rxsize As Byte
rxsize = 49
'Dim csv As Byte
Symbol dataswitch_S0 = LATD.5 'C/S S0=L S1=L =TX4431, S0=L S1=H =HC-12, S0=H S1=L =GPS
Symbol dataswitch_S1 = LATD.6
Dim datasw As Byte 'For setting next in sequence of DATASWITCH
datasw = 0 '1st in sequence GPS
'PIC18F4431
Dim qeideg As String
'REMOTE from distance
Dim remvolt As Byte
Dim strremvolt As String
Dim remalt As Byte
Dim strremalt As String
Dim remdist As Byte
Dim strremdist As String
'HC-12 RADIO
Symbol radset = LATD.4 'HC-12 0=COMMAND ON 1=DATA ON
'INITIALISATION
'PRESS BUTTON (OR RADSET)
radset = 0 'SET HC-12 COMMAND ON
WaitMs 100
Hserout "AT+C002", CrLf '433.800
WaitMs 100
radset = 1 'SET HC-12 RUN ON
WaitMs 100
rxin = 0
msg_rdy = 0
Enable High
main: '/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\
If buf_done = 1 Then
buf_done = 0 'Buf filled
prs_fill = 1
Gosub parse
prs_fill = 0
prs_done = 1 'Parse Done
Endif
If prs_done = 1 Then
strbuf = ""
'...SET DATASWITCH: 'S0=1 S1=0 =TX4431, S0=0 S1=H =HC-12, S0=0 S1=0 =GPS
Gosub switch
'To avoid A framing error, you are best To !!switch dataswitch!! between Ascii characters
'by checking BAUDCON.RCIDL=1. If it is =1,
'Then the UART is idle And Not receiving any serial data stream.
'If BAUDCON.RCIDL = 1 Then 'Avoid framing error-BIT6 NEVER 1! in SIM
'rled = 1
'yled = 1
WaitMs 500 '//////////////////////////////////////////////
RCSTA.CREN = 1 'INTERRUPT ENABLED
PIE1.RCIE = 1 'ENABLEs EUSART RECEIVE INTERRUPT
cnt = 0
rxpsn = 0
prs_done = 0 '!!!!!!!!!!!!!!!!!!!!!!!!!!!
'Endif
Endif
If Len(strtim) <> 0 Then 'if string is zero length don't hserout........
Hserout "T=", strtim, " N=", strlat, " W=", strlong, CrLf
'WaitMs 5 '????????????
Endif
If Len(qeideg) <> 0 Then
Hserout "QEIDEG= ", qeideg, CrLf 'QEIDEG=BASE 4431 Opto encoder
Endif
If Len(strremvolt) <> 0 Then
Hserout "REMVOLT=", strremvolt, " REMALT=", strremalt, " REMDIST=", strremdist, CrLf
Endif
'INTCON.GIE = 1 '!!!!!!
Goto main
End
On High Interrupt
Save System
'BIT1..if over run error then flush RXD buffer
'BIT2..framing error(can be cleared by reading RCREG register And receiving Next valid Byte)
If RCSTA.OERR = 1 Or RCSTA.FERR = 1 Then
RCSTA.CREN = 0
RCSTA.CREN = 1 'BIT4 ENABLES RECEIVER
char = RCREG '1
char = RCREG '2
err = 1 'ERROR
Endif
If PIR1.RCIF = 1 Then
char = RCREG
If char = "$" Then
rxpsn = 0
buf_fill = 1
Endif
If buf_fill = 1 Then
buf(rxpsn) = char
If rxpsn < 50 Then
rxpsn = rxpsn + 1
Endif
Endif
If buf(0) = "$" And char = "W" Then
RCSTA.CREN = 0 'INTERRUPT DISABLED
PIE1.RCIE = 0 'DISABLEs EUSART RECEIVE INTERRUPT
buf_fill = 0
buf_done = 1
Endif
Endif
Resume
parse:
'These subrs' extract the main values from the GPS,REMOTE and QEIDEG strings, into named value messages
'also converts the strings to a named numeric values, for maths
For cnt = 1 To rxpsn
char = buf(cnt)
strchr = Chr(char)
strbuf = strbuf + strchr
If buf(5) = "C" Then '0 in DATASWITCH sequence
strtim = MidStr(strbuf, 7, 2) + ":" + MidStr(strbuf, 9, 2) + ":" + MidStr(strbuf, 11, 2)
strlat = MidStr(strbuf, 19, 10) 'POSITION_Number of digits in the STRING
strlong = MidStr(strbuf, 33, 8)
datasw = 1
Else
If buf(1) = "R" Then '1 in sequence
strremvolt = MidStr(strbuf 8, 2)
strremalt = MidStr(strbuf 11, 2)
strremdist = MidStr(strbuf 14, 2)
datasw = 2
Else
If buf(1) = "Q" Then '2 in DATASWITCH sequence
qeideg = MidStr(strbuf, 8, 3)
datasw = 0
Endif
Endif
Endif
Next cnt
Return
switch:
''SET DATASWITCH: 'S0=0 S1=0 =GPS--S0=1 S1=0 =REMOTE--S0=0 S1=1 =TX4431,
If datasw = 0 Then
Hserout "DATASW= ", #datasw, CrLf
dataswitch_S0 = 0 'GPS
dataswitch_S1 = 0
rled = 0
yled = 0
Else
If datasw = 1 Then
dataswitch_S0 = 1 'REMOTE HC-12
dataswitch_S1 = 0
rled = 1
yled = 0
Else
If datasw = 2 Then
dataswitch_S0 = 0 'QEI 4431
dataswitch_S1 = 1
rled = 0
yled = 1
Endif
Endif
Endif
Break '!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WaitMs 50 '???????????????????????
Return
That's because you change the channel (datasw) as a SIDE EFFECT of the parse routine then call switch at 'If prs_done = 1'. You want to strap down the channel to the REMOTE input. The problem with side effects like this is exactly what we see - you have to butcher up unrelated code to make changes. As I, and likely others along the way, have indicated above, the switching channels should be it's own routine set that does the switch when called INDEPENDENTLY of any other operation like parsing. Stuffing unrelated things together like you have here is a recipe for long nights of fruitless debugging. You will lilely find it difficult to do any changes without breaking something else because it's all smooshed together into a lumpy mass.I've tried testing with the DATASWITCH only pointing to REMOTE, but it still READS GPS and 4431 This could be an error on my part.
Hi JT,Let's start with the stripped down one..
==========================================================REMOTE ONLY:'18LF4620 8MHz XTL BASE PCB_4 INT_PAR REMOTE only 300620 0900 Define CONFIG1L = 0x00 Define CONFIG1H = 0x02 '0x02 =EXT 8MHz Define CONFIG2L = 0x1e Define CONFIG2H = 0x00 Define CONFIG3L = 0x00 Define CONFIG3H = 0x81 'Set for HVP Define CONFIG4L = 0x80 Define CONFIG4H = 0x00 Define CONFIG5L = 0x0f Define CONFIG5H = 0xc0 Define CONFIG6L = 0x0f Define CONFIG6H = 0xe0 Define CONFIG7L = 0x0f Define CONFIG7H = 0x40 Define SIMULATION_WAITMS_VALUE = 1 'Comment in for SIM out for PIC Define CLOCK_FREQUENCY = 8 Define SINGLE_DECIMAL_PLACES = 2 Define STRING_MAX_LENGTH = 40 'SET PIN IN/OUT TRISA = %00000000 TRISB = %00000000 TRISC = %10000000 '7 = RX TRISD = %00000000 TRISE = %00000000 'SET BITS ON/OFF PORTA = %00000000 'ON/OFF PORTB = %00000000 LATB = 0 PORTC = %00000000 PORTD = %00000000 PORTE = %00000000 'POSS MCLR RE3 WaitMs 10 'set up interrupts RCON.IPEN = 1 '%10000000 Int Priority Enable bit 'This MUST be included when using Interrupts (Priority HIGH/LOW)[#189 hserin blocking] PIE1.RCIE = 1 '%00100000 EUSART Receive Interrupt Enable bit [ 1=en ] INTCON.PEIE = 1 '%01000000 Peripheral Interrupt Enable bit INTCON.GIE = 1 '%10000000 Global Interrupt Enable bit ''BAUDCON.BRG16 = 1 '%00001000 1 = 16-bit Baud Rate Generator – SPBRGH and SPBRG TXSTA.SYNC = 0 '%00010000 = Asynchronous mode RCSTA.SPEN = 1 '%10000000 1 = Serial port enabled (configures RX/DT and TX/CK pins as serial port pins) RCSTA.RX9 = 0 '%01000000 0 = Selects 8-bit reception RCSTA.CREN = 1 '%00010000 1 = Enables receiver 'Read the 8-bit received data by reading the RCREG register. 'If any error occurred, clear the error by clearing Enable Bit, CREN. 'If using interrupts, ensure that the GIE And PEIE bits in the INTCON register(INTCON < 7: 6 >) Symbol yled = LATE.1 Symbol rled = LATE.2 'START UP LEDS yled = 1 rled = 1 WaitMs 1000 yled = 0 rled = 0 WaitMs 1000 '**** Setup Hw USART **** Hseropen 9600 Hserout "READY", CrLf Dim char As Byte Dim buf(50) As Byte '*** received message comes to buf Dim rxin As Byte 'ïndex To buf ''Dim cnt As Byte Dim msg_rdy As Bit Dim err As Bit 'Errors in receiving $DATA 'GPS and REMOTE Dim strchr As String 'GPGGA or $REMOTE msg Dim sinlat As Single 'For calculation Dim sinlong As Single 'For calculation Dim strtim As String Dim strlat As String Dim strlong As String Dim cnt As Byte 'CHARs counted through buf Dim strbuf As String Dim buf_fill As Bit 'Message loading Dim buf_done As Bit 'Buffer $ to W 1 = Done 0 = Not Dim prs_fill As Bit Dim prs_done As Bit 'Empty Buffer now, it has been READ. as 1 = Don Dim rxpsn As Byte Dim rxsize As Byte rxsize = 49 'Dim csv As Byte Symbol dataswitch_S0 = LATD.5 'C/S S0=L S1=L =TX4431, S0=L S1=H =HC-12, S0=H S1=L =GPS Symbol dataswitch_S1 = LATD.6 Dim datasw As Byte 'For setting next in sequence of DATASWITCH datasw = 0 '1st in sequence GPS 'PIC18F4431 Dim qeideg As String 'REMOTE from distance Dim remvolt As Byte Dim strremvolt As String Dim remalt As Byte Dim strremalt As String Dim remdist As Byte Dim strremdist As String 'HC-12 RADIO Symbol radset = LATD.4 'HC-12 0=COMMAND ON 1=DATA ON 'INITIALISATION 'PRESS BUTTON (OR RADSET) radset = 0 'SET HC-12 COMMAND ON WaitMs 100 Hserout "AT+C002", CrLf '433.800 WaitMs 100 radset = 1 'SET HC-12 RUN ON WaitMs 100 rxin = 0 msg_rdy = 0 Enable High main: '/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\ If buf_done = 1 Then buf_done = 0 'Buf filled prs_fill = 1 Gosub parse prs_fill = 0 prs_done = 1 'Parse Done Endif If prs_done = 1 Then strbuf = "" '...SET DATASWITCH: 'S0=1 S1=0 =TX4431, S0=0 S1=H =HC-12, S0=0 S1=0 =GPS Gosub switch 'To avoid A framing error, you are best To !!switch dataswitch!! between Ascii characters 'by checking BAUDCON.RCIDL=1. If it is =1, 'Then the UART is idle And Not receiving any serial data stream. 'If BAUDCON.RCIDL = 1 Then 'Avoid framing error-BIT6 NEVER 1! in SIM 'rled = 1 'yled = 1 WaitMs 500 '////////////////////////////////////////////// RCSTA.CREN = 1 'INTERRUPT ENABLED PIE1.RCIE = 1 'ENABLEs EUSART RECEIVE INTERRUPT cnt = 0 rxpsn = 0 prs_done = 0 '!!!!!!!!!!!!!!!!!!!!!!!!!!! 'Endif Endif If Len(strtim) <> 0 Then 'if string is zero length don't hserout........ Hserout "T=", strtim, " N=", strlat, " W=", strlong, CrLf 'WaitMs 5 '???????????? Endif If Len(qeideg) <> 0 Then Hserout "QEIDEG= ", qeideg, CrLf 'QEIDEG=BASE 4431 Opto encoder 'WaitMs 5 '?????????? Endif If Len(strremvolt) <> 0 Then Hserout "REMVOLT=", strremvolt, " REMALT=", strremalt, " REMDIST=", strremdist, CrLf 'WaitMs 5 '?????????? Endif 'INTCON.GIE = 1 '!!!!!! Goto main End On High Interrupt Save System 'BIT1..if over run error then flush RXD buffer 'BIT2..framing error(can be cleared by reading RCREG register And receiving Next valid Byte) If RCSTA.OERR = 1 Or RCSTA.FERR = 1 Then RCSTA.CREN = 0 RCSTA.CREN = 1 'BIT4 ENABLES RECEIVER char = RCREG '1 char = RCREG '2 err = 1 'ERROR Endif If PIR1.RCIF = 1 Then char = RCREG If char = "$" Then rxpsn = 0 buf_fill = 1 Endif If buf_fill = 1 Then buf(rxpsn) = char If rxpsn < 50 Then rxpsn = rxpsn + 1 Endif Endif If buf(0) = "$" And char = "W" Then RCSTA.CREN = 0 'INTERRUPT DISABLED PIE1.RCIE = 0 'DISABLEs EUSART RECEIVE INTERRUPT buf_fill = 0 buf_done = 1 Endif Endif Resume parse: 'These subrs' extract the main values from the GPS,REMOTE and QEIDEG strings, into named value messages 'also converts the strings to a named numeric values, for maths For cnt = 1 To rxpsn char = buf(cnt) strchr = Chr(char) strbuf = strbuf + strchr If buf(5) = "C" Then '0 in DATASWITCH sequence strtim = MidStr(strbuf, 7, 2) + ":" + MidStr(strbuf, 9, 2) + ":" + MidStr(strbuf, 11, 2) strlat = MidStr(strbuf, 19, 10) 'POSITION_Number of digits in the STRING strlong = MidStr(strbuf, 33, 8) datasw = 1 Else If buf(1) = "R" Then '1 in sequence strremvolt = MidStr(strbuf 8, 2) strremalt = MidStr(strbuf 11, 2) strremdist = MidStr(strbuf 14, 2) datasw = 2 Else If buf(1) = "Q" Then '2 in DATASWITCH sequence qeideg = MidStr(strbuf, 8, 3) datasw = 0 Endif Endif Endif Next cnt Return switch: ''SET DATASWITCH: 'S0=0 S1=0 =GPS--S0=1 S1=0 =REMOTE--S0=0 S1=1 =TX4431, If datasw = 0 Then Hserout "DATASW= ", #datasw, CrLf dataswitch_S0 = 0 'GPS dataswitch_S1 = 0 rled = 0 yled = 0 Else If datasw = 1 Then Hserout "DATASW= ", #datasw, CrLf dataswitch_S0 = 1 'REMOTE HC-12 dataswitch_S1 = 0 rled = 1 yled = 0 Else If datasw = 2 Then Hserout "DATASW= ", #datasw, CrLf dataswitch_S0 = 0 'QEI 4431 dataswitch_S1 = 1 rled = 0 yled = 1 Endif Endif Endif Break '!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WaitMs 50 '??????????????????????? Return
Other issues:
You enable interrupts before configuring the serial port.. configure first, enable last. Consider what happens if you get an interrupt before initializing the buffer and index.
EDIT: Ignore comment re: RCIP=1
IMHO, you won't get much further until you fix the interrupt error handling. I don't think it's possible with your scheme to switch channels without generating some errors and you're not handling them.
I purchased OSH so that I can follow along. If you want to proceed with straightening this out in a structured, orderly manner we can take a shot at that. Much of what others brought up in these threads will apply so think about that. I really don't see any way other than dumb luck to get to success otherwise.
Thoughts?
'Set up UART and interrupts
Hseropen 9600
Don't do anything yet.Thoughts?, "lumpy mass". What! after weeks of artful crafting
More thoughts? That's fine, I'll re-do it.
I posted a comment re: RCIP because you didn't use it to set the priority of the receive interrupt to 'high'. As it is, the default value is OK so let's not worry about that now.Where is: EDIT: Ignore comment re: RCIP=1
Let's defer that discussion for right now. In general, the main loop should just call a series of subroutines each of which is written to do ONE function only. I suggested some things above, UART controls, channel switching etc., as examples. Before proceeding, I'll detail what I wrote as an example, test it then post for your review. If you can get on board with the ideas presented, where to put the calls to them will be self-evident.'ve marked a section of your reply with ========================
While I kind of understand what you are suggesting, I don't know quite what you mean. Are you suggesting that most of what's in the MAIN LOOP should be in a SUBROUTINE?
Yeah.. it's not incorrect OR correct, it's just one way of doing things suggested to fix an immediate problem. Flags are fine for now. You should note that a big problem with forum help, including mine, is that you will hear many different ways of doing the same thing based of the particular member's experience, paradigms and indeed what they think you can handle. You have to be ready to guide the discussion and help to stay in your comfort zone.EDIT: Looking through your ========== paragraph regarding the [PRS_DONE] and the switching. Earlier I was advised to use FLAGS. My interpretation of that was to set PRS_DONE to 1 after the $-W sentence had been PARSED, then switch to the next INPUT in the sequence. Is this incorrect?
Hi JT,Here's a better interrupt service routine and a helper that inits the buffer. Replace your current interrupt routine with these. It should manage errors and other issues better than what you have now. I tested as as able with the OSH simulator.. hmmm. the sim has some fidelity issues e.g. it doesn't manage the FERR or OERR flags like the PIC hardware does but you can set/clear them manually. You should read through it and convince yourself that it works like you expect. Note that you'll have to add a declaration for rxBufSize as described in the comments.
UART setup has some routines that manage the UART and data selection in a consistent manner rather than burying channel selection in the parse stuff. Review them to see if you like the idea. Then you can clean up your main loop to use these to change/update channels. If it works once, it will work always (it says here )
Have fun!
Hi JT,Hi JT,
A reply to both of your messages.
There's a lot there but I'll have a go.
I've copied your 2x routines, thanks.
You seem to have picked up the OSH language remarkably fast, unless you knew it before?
Regarding help from other members, and the Oshonsoft simulator.
I rely completely on this simulator, as I will never be a good programmer, but we've found that there are issues with it. Other forum members, have written ASM CODE as a get round, for small sections.
I also rely on help from this and other forums, and have been able to make some really good electro/mechanical things, that wouldn't have been possible and well beyond my capabilities, without them, thanks to all.
I hoped to write my own INTERRUPT PARSE routine, but as mentioned, came to the end of my limits before finishing. I'll add your sections, into the MAIN program, and of course report back.
Cheers, C.
Hi JT,You have an interesting way of taking discrete structure and mashing it flat.
Why is 'main' wedged between the comments and code section of the interrupt routine?!? That is a functional block from the header bar to 'Resume' and nothing unrelated to its function goes there.
I reorganized the code but didn't test it. But note how the basic code function is described in main and everything else is just support routines. That's how to organize things. Reading 'main' should show completely what the code does, no more no less.
Main now says:
Assume that the system is initialized and channel number is set
Set up the UART and buffer to receive a sentence from that channel
Wait for the sentence
Process the sentence
Change the channel (but we're sticking with one for now so that's commented out)
Loop and do it again
Note how that describes everything the program does right there in one place - things like setting the UART channel, buffer management, parsing and EVERYTHING else is deferred to subroutines..
In particular, look at the channel control. It's all right there in one small block, not scattered inside unrelated routines. I removed channel changing from parse and put it in main where it belongs. That way you can control the channel independent of parsing. In this case, controlling the channel means setting it to RADIO and not changing it so that the channel can be debugged. Nice.
There's more but let's see how you do with that.
Have fun!
If datasw = 0 Then
dataswitch_S1 = 0
rled = 0
yled = 0
Goto chan_set
Endif
If datasw = 1 Then
dataswitch_S1 = 0
rled = 1
yled = 0
Goto chan_set
Endif
If datasw = 2 Then
dataswitch_S1 = 1
rled = 0
yled = 1
Endif
There isn't any LOOP but good catch on the missing goto.Does the last LOOP here also need the [Goto chan_set] line?
I didn't but I tend to separate the problem-solving aspect of a task from the nuts and bolts of whatever language I'm using. I'm vaguely familiar with BASIC but mostly emulated your syntax to get going so thanks for that.You seem to have picked up the OSH language remarkably fast, unless you knew it before?
I disagree. If nothing else, you've shown incredible perseverence in the face of a task that you're not fully equipped to deal with. No shame there. If you haven't noticed, the goal is to get you to re-think how to approach your problem i.e. as a series of little tasks. Get them working one by one. Put them together into something bigger. Along the way, we both have things to learn. Why not?I rely completely on this simulator, as I will never be a good programmer
Hi JT,I didn't but I tend to separate the problem-solving aspect of a task from the nuts and bolts of whatever language I'm using. I'm vaguely familiar with BASIC but mostly emulated your syntax to get going so thanks for that.
My inexperience is showing, though. I noticed that OSH is complaining (compiler warnings) about me using GOTOs out of setGPSchannel, setREMOTEchannel and setQEIchannel routines. That is a legitimate gripe and indicates that it's more structured than I thought so we'll change that. Lesson learned. There are a few more cleanups I think we need but that's later.
I mention this to illustrate why I objected to your 'main' routine in the middle of my interrupt service file. If we were to replace module with an improved version, selecting and replacing the module would also wipe out your main routine. So... respect the modules. In the source, they should start with some kind of header line and end with the last line of code being a return or goto to end the module. A couple of blank lines at then end of all of that visually separates the modules - for me at least.
As I noted, the code in #234 doesn't switch channels, it stays on the radio channel because you were having problems with that one. All you have to do to fix that is remove the comment in main on line 13. Then it will cycle through the channels.I tried your #234 CODE, which nearly worked, but didn't switch the [setUARTchannel: where dataswitch_S0 and dataswitch_S1 and LEDs are switched]
Gosub setUARTchannel ' start UART on channel(datasw), begins looking for sentence
If buf_done = 1 Then '
buf_done = 0 '
prs_fill = 1 '
Gosub parse ' parse received sentence
prs_fill = 0 '
prs_done = 1 '
' end of processing for now, update channel as necessary and loop
' at this point, we just stay on RADIO channel
'Gosub next_channel <<<<<-------------- remove this comment to enable channel switching
Endif '
Goto main
Fair point. Interrupt routines should be kept short with minimal processing time. That means no delays, minimal loops, no math processing etc. Get in, do the minimum you have to and leave.I was also advised to keep the INTERRUPT short with no GOSUBS, I don't know what short is?
There aren't any delays in the code I sent. That may be the reason it seems fast. That's a good thing.It went really fast, then after a while stopped completely, I don't know why.
' move channel switching out of loop <------
buf_done = 0 '
prs_fill = 1 '
prs_fill = 0 '
prs_done = 1 '
'Gosub next_channel
Endif '
Goto main
End ' don't really need this as main stays in a loop
Yeah, different visual styles, I guess. No problem there. As for the GOSUBS and chronological order, can you strike a balance? For example, the main code above runs the system in chronological order and fits on one page. That is made possible by using the gosubs. Once you have the subroutines debugged, they just become extensions of the BASIC language and your program does what you read in main and in that order - fits on one page too! If you can get yourself into that mind-set you will find your programming much easier.I think you like gaps between each CODE module, for clarity, where I like more on the page, as once I scroll I forget what was there before I also prefer if things are in chronological order as I proceed down the CODE if possible, remembering that GOSUBS etc jump about a bit.
Hi JT,As I noted, the code in #234 doesn't switch channels, it stays on the radio channel because you were having problems with that one. All you have to do to fix that is remove the comment in main on line 13. Then it will cycle through the channels.
Code:main: '/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\ Gosub setUARTchannel ' start UART on channel(datasw), begins looking for sentence If buf_done = 1 Then ' buf_done = 0 ' prs_fill = 1 ' Gosub parse ' parse received sentence prs_fill = 0 ' prs_done = 1 ' ' end of processing for now, update channel as necessary and loop ' at this point, we just stay on RADIO channel 'Gosub next_channel <<<<<-------------- remove this comment to enable channel switching Endif ' Goto main
You can have subroutines in an interrupt handler if you use them correctly. The advantage of the subroutine to init the buffer is that it works the same each time. The disadvantage of using subroutines in an interrupt is 1)it uses a little more time 2)it uses some stack which in the old mid-range PICs, was an issue. The 18F has enough stack to handle a few subroutines.
Lockups: Are you running on the actual hardware?
If so, try this version of main as a test:
This sets up the channel once then just reads with no channel switching. If that takes care of your lockups then we have more work to do on the channel switching and error recovery. If not, we keep looking. I would not proceed until you can read one channel perfectly over and over WITH the call to setUARTchannel. Another member PM'd me with a concern about the IRQ code. I didn't think it had a problem but will revisit that.Code:' move channel switching out of loop <------ Gosub setUARTchannel ' start UART on channel(datasw), begins looking for sentence main: '/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\ If buf_done = 1 Then ' buf_done = 0 ' prs_fill = 1 ' Gosub parse ' parse received sentence prs_fill = 0 ' prs_done = 1 ' ' end of processing for now, update channel as necessary and loop ' at this point, we just stay on RADIO channel 'Gosub next_channel Endif ' Goto main End ' don't really need this as main stays in a loop
But at this point, getting the comms solid is the goal. After that, you can write as you can.
Final question: Is there any delay between sentences in the RADIO channel? If so, how much? If not, can you add some? 3-4ms would do it.
Good luck!
