Oscilloscope and noise
Rufinus
Joined Apr 29, 2020
307
Hello. I have just bought an oscylloscope, a RIGOL DS1054Z
It seems to work OK, but in I got these results (it is properly grounded) (in x10)
Without probe
With the probe but nothing connected to it
Here are the specs
I suposse that is normal because the vertical scale is just 10mV per division, but I just want to be sure. Of course, when I connect the 2 endes of the probe each other, it reduces a lot.
Thank you
Best regards
34,807
That is normal.
A probe is like a radio antenna. It will pick up all radio, phone, wifi signals, and especially AC 50/60 Hz.
Set the horizontal scale (SEC/DIV) to 5 or 10 ms and observe the AC line frequency. Then touch the tip of the probe with your finger.
rsjsouza
Joined Apr 21, 2014
425
Indeed this is absolutely normal and can also be seen when leaving multimeters with their inputs open - the values on its display fluctuate constantly.
Just an interesting test: there is a setting that limits the bandwidth to 20MHz. If you enable it, you can see the noise is reduced since a large part of the spectrum will be filtered.
