oscilator
angangry
Joined Jun 2, 2023
11
I want to build a oscillator that operates
I have tried various combinations of L and C, but I cannot. What should I do?
Danko
Joined Nov 22, 2017
2,250
Danko
Joined Nov 22, 2017
2,250
I'm unable to achieve oscillation, let alone obtain a frequency of 100MHz with your circuit
Q factor? May be. So what is resistance of your coil? Mine is 1 mΩ.
But my circuit does not work
with such (your) configuration: _____________________This is working:
ADDED: With and without C5
LvW
Joined Jun 13, 2013
2,046
I'm unable to achieve oscillation, let alone obtain a frequency of 100MHz with your circuit. What should I do to address this issue
and Should the Q factor be considered when determining the values of L and C ? .. TT Plz
No, the Q-factor of the coil is less important.
Basic rule: When an oscillator circuit does not work, you must check the oscillation condition by displaying the loop gain (Magnitude and phase) - as I have recommendd already in post#6.
Anything else is "try and error (and hope)".
S General Electronics Chat 4
