OrCAD Pspice Transient Time Point Iteration Limit
BlackMelon
Joined Mar 19, 2015
85
I have increased the Transient Time Point Iteration from 20 to 150 and got an error as in the text file. The simulation worked fine with 20.
How to fix the problem?
Thank You
BlackMelon
GopherT
Joined Nov 23, 2012
8,012
Thank You
BlackMelon
Why do you want such a large time step? Just based on my experience with other simulation software (outside of electronics), You are likely causing the simulator to go crazy because the time constant of some of your LCR networks are below your time steps.
Actually, a decently accurate simulation should require time steps to be about 1 to 5% of the time constant.
Switch back to 20.
