Optocupler behaviour explanation
Domen Ulbl
Joined Jul 4, 2016
6
Hello!
It's my first time here on AAC. I bought some MOC 3061 optocuplers and I am planning to use them as switches to open or close another circuit. For testing purposes I've build the following circuit:
[/url][/IMG]
The 5V source is an Arduino with a button hooked up to act as a switch. The circuit I plan to control is powered by 9V battery and contains two 100Ohm resistors and a green LED1.
Can somebody explain why the triac driver (is this correct?) continues to conduct after the current stops flowing through the 5V circuit?
Any help would be greatly appreciated!
OBW0549
Joined Mar 2, 2015
3,566
Because that's the way triacs work. To turn them on, they only need a brief pulse on the gate; to turn them off, you have to interrupt the flow of current through them. SCRs are the same way.
32,840
Because that's what triacs do!
Think of them as a self-latching relay. Once you power it up with a shot of current, the current that starts flowing in the main circuit keeps the device on. To shut it off, you have to momentarily remove the current in the main circuit. After that, it will be off until the next shot of current form the control circuit. This is why triacs are normally used in AC circuits -- the zero crossing is enough to shut them off. It sounds like you want a normal phototransistor output stage.
Domen Ulbl
Joined Jul 4, 2016
6
I guess I learn something new everyday....
So what kind of an optocupler (or other element) should I get to act as a regular DC switch?
Eventually I plan to control a camera flash with 80V between the terminals.
30,661
Your circuit is not complete, how are you switching the triac on, You could sub it for a logic level Mosfet.
Use transistor output opto.
32,840
The circuit shown is complete. It's an optically coupled triac -- the light from the LED (D2) produces electron-hole pairs at the triac's gate.
Though before I commit to that too firmly, let me look up those part numbers. I expected a single part number, not two.
Domen Ulbl
Joined Jul 4, 2016
6
The circuit of the MOC is VERY approximate. the actual circuit is like that:
where terminals 1,2 & 4,6 are connected. Substituting this optocupler for a one with a regular mosfet instead of the triac should work then?
32,840
Hello!
[/url][/IMG]
Your schematic is confusing -- it show two discrete parts (with discrete part numbers) but then with a red box around them and a different part number. Are you using/simulating two discrete parts or a single optocoupler?
Also, are you simulating this or describing the behavior of a physical circuit you've constructed?
Domen Ulbl
Joined Jul 4, 2016
6
I admit this schematic is confusing. I have the physical circuit in front of me, in which I am using the MOC 3061 optocupler. I used discrete elements in the schematic because i could not find an optocupler in the element libraries.
EM Fields
Joined Jun 8, 2016
583
Your circuit isn't at all representative of an MOC3061 but, no matter how you've contrived to turn the TRIAC ON, the reason you can't turn the TRIAC OFF is because in order to do that you must reduce the current into the load to be close to zero while the gate signal is OFF.
OBW0549
Joined Mar 2, 2015
3,566
If your end use of this circuit is to trigger a photoflash, the MOC3061 might actually be appropriate for the job. Photoflash triggering is normally done by discharging a capacitor into the primary of a small step-up transformer, producing a pulse of several kV which initiates the ionization in the flash tube, which then discharges the main photoflash capacitor, producing light. If I recall correctly, SCRs or triacs are usually used for this purpose, as shown here, so you may be OK.
32,840
What are the details on this flash unit. Many flash units have a control signal input that is either a logic level signal or activated by pulling a floating pin to common. Or are you digging into a flash unit and trying to jury rig a control signal into a unit that wasn't intended to have one? Or are you trying to build a flash unit from scratch? A bit of detail about what you are actually trying to accomplish might get you information that is more relevant to your needs.
Domen Ulbl
Joined Jul 4, 2016
6
What I am trynig to accomplish is to make a circuit that could trigger the flash when voltage is applied to the optocupler by the arduino.
The flash I use is the Metz 30 bct 4. The voltage measured between the terminals on the foot of the flash is about 74V.
The actual circuit:
The upper part is the same as original schematic: 5v output from arduino connected over resistors to pins 1&2 on the MOC 3061. The flash is connected to pins 4&6 as is the voltmeter. When voltage is applied to pins 1&2, the voltmeter reading goes to zero immediately but the flash does not fire. The only way to trigger the flash is to (manually) short the pins on the foot.
I would appreciate some insight as to what might be going on.
