optocoupler switching issue
ak52
Joined Oct 15, 2014
241
Hi guys,
In the below circuit,i am facing issues trying to switch a 10KHz PWM signal.
I get a proper pulse at pin 2 w.r.t 3rd pin,but at the output side(pin 6 w.r.t pin 5) i see no pulse.
G1 is 12v w.r.t. pin 5.
At the moment GATE1 is open.I plan to connect it to an NMOS once i see an output pulse.
I tried changing the input resistance to 100 ohm, increased and decreased the values of C22 and C23 and changed the optocoupler also.
What else can i try ?
Thanks,
AK :)
ak52
Joined Oct 15, 2014
241
Show us the complete schematic.
That is the complete circuit,i have split it up in two ,
G1 and G2 is 12v.
the DC DC converter with provides the 12 v is given below:
If anything else is required please tell, i will post it.
Kjeldgaard
Joined Apr 7, 2016
476
As Eric writes, the supply is too low. The threshold values for under voltage protection (Table 10: UVLO) is actually around 12 Volt.
I see no reason for C32. It can be removed as you normally seeks a low GS capacity, as to reduce switching loss.
As R26, I would choose 10 K Ohm.
