I cant figure out how to find the differential output voltage of a differential amp. the problem gives me collector resistor and current values. Can you help?
maybe, posting a circuit diagram would be a good startI cant figure out how to find the differential output voltage of a differential amp. the problem gives me collector resistor and current values. Can you help?
Fully differential op-amps do.An opamp doesn't have a differential output.
OpAmps in parallel | General Electronics Chat | 21 | |
Dynaco solid-state pre-amps (resistor values, 1/4 or 1/2 watt) | General Electronics Chat | 12 | |
| K | Variable Constant Current Supply using Parallel Op Amps | General Electronics Chat | 44 | |
Wien bridge oscillator without op amps | General Electronics Chat | 5 |
