Operational Amplifier
Hitman6267
Joined Apr 6, 2010
82
Look at bottom of the thread for my latest question
I tried solving it using the equation
Vo/4 +1 + 1/8 =0
But it didn't work. What am i doing wrong ?
Hitman6267
Joined Apr 6, 2010
82
That's the same equation I posted. Its answer is Vo = -4.5. The web-form where I submit my answer says it's wrong.
Jony130
Joined Feb 17, 2009
5,601
If we solve this
\(\frac{(Vs-0V)}{R1}-\frac{(0V-V1-Vout)}{R2}=0\)
then we get:
Vout = - V1 - R2/R1*Vs = -4V - 0.5V = - 4.5V
Hitman6267
Joined Apr 6, 2010
82
Yes exactly like I said in the post above. And it turns out it's right. The system is accepting it as an answer now. Thank you.
hgmjr
Joined Jan 28, 2005
9,027
Write Millman's Theorem equation for voltage at opamp minus input terminal by inspection:
\(V_- =\Large \frac{\frac{V_S}{R_1}+\frac{V_o+V_1}{R_2}}{\frac{1}{R_1}+\frac{1}{R_2}}\)
Ideal Opamp Equation:
\({V_-=V_+=0}\)
Simplify first equation above:
\(0=\frac{R_2V_s+R_1(V_o+V_1)}{R_1+R_2}\)
\(0={R_2V_s+R_1(V_o+V_1)}\)
\(0={R_2V_s+R_1V_o+R_1V_1}\)
\(-R_1V_o={R_2V_s+R_1V_1}\)
\(V_o=-\frac{R_2V_s+R_1V_1}{R_1}\)
\(V_o=-\frac{R_2V_s}{R_1}-\frac{R_1V_1}{R_1}\)
\(V_o=-\frac{R_2V_s}{R_1}-V_1\)
Plug in values:
\(V_o=-\frac{4(1)}{8}-4\)
\(V_o=-0.5-4\)
\(V_o=-4.5V\)
Just thought someone might be interested in seeing how Millman's Theorem could be used to solve this problem.
hgmjr
Hitman6267
Joined Apr 6, 2010
82
Let the output of the first op amp be Vo and the output of the second Vo'
I calculated Vo from the equation 4/9 + vo/4 = 0
So I got Vo = -1.78
Then I wrote these equations for the second op amp.
(Vo -Vp)/9 + Vp/4 =0
=> Vp =1.42
(Vo-Vn)/4 + (Vo' -Vn)/9 =0
=> Vo' = 8.62
What's wrong here ? My answer is wrong.
The Electrician
Joined Oct 9, 2007
2,986
So I got Vo = -1.78
=> Vp =1.42
=> Vo' = 8.62
One problem is that (Vo -Vp)/9 + Vp/4 =0 should be (Vp -Vo)/9 + Vp/4 =0
hgmjr
Joined Jan 28, 2005
9,027
So I got Vo = -1.78
=> Vp =1.42
=> Vo' = 8.62
Here is the solution to the second gain stage using Millman's Theorem.
First I form the Millman's Theorem expression for the voltage at the inverting input to the second stage. I am using e(-) to refer to the voltage at the inverting input to the second stage opamp.
\(e_{(-)} = \frac{\frac{V_i}{R_2}+\frac{V_o}{R_1}}{\frac{1}{R_1}+\frac{1}{R_2}}\)
Second, I form the Millman's Theorem expression for the voltage at the non-inverting input to the second stage. I am using e(+) to refer to the voltage at the non-inverting input to the second stage opamp.
\(e_{(+)} = \frac{\frac{V_i}{R_1}}{\frac{1}{R_1}+\frac{1}{R_2}}\)
I now set these two expressions equal to each other since that is the case with an ideal opamp.
\(\frac{\frac{V_i}{R_2}+\frac{V_o}{R_1}}{\frac{1}{R_1}+\frac{1}{R_2}} = \frac{\frac{V_i}{R_1}}{\frac{1}{R_1}+\frac{1}{R_2}}\)
Then I begin the simplification process by first eliminating the denominator on both sides since they are equal.
\(\frac{V_i}{R_2}+\frac{V_o}{R_1} = \frac{V_i}{R_1}\)
Next I multiply both sides by R1*R2 to get rid of the fractions.
\(R_1V_i+R_2V_o = R_2V_i\)
\(R_2V_o = R_2V_i-R_1V_i\)
\(R_2V_o = V_i(R_2-R_1)\)
\(V_o = \frac{V_i(R_2-R_1)}{R_2}\)
The final equation above is the expression for the gain of the second stage only of the two stage amplifier. Vi in this expression is the output of the first opamp stage.
hgmjr
