operational amplifier
35,198
The operational amplifier is perhaps the most important invention in all of electronics apart from the transistor itself.
What is an operational amplifier?
An opamp is a wide bandwidth amplifier with high gain. An ideal opamp is commonly treated as a functional black box in circuit design without requiring any knowledge of the internals of its construction.
An ideal opamp has the following properties:
  1. Infinite input impedance
  2. Zero output impedance
  3. Infinite voltage gain
  4. Infinite bandwidth
With such perfect properties, the application of opamp is without limit.
Reference: https://en.wikipedia.org/wiki/Operational_amplifier
38,847
Don't forget that modern operational amplifiers have a differential input with ideally zero DC offset (but the first tube operational amps only had a negative input referenced to ground).
LvW
Joined Jun 13, 2013
2,038
....and the most important property of the opamp is the following:
Due to is huge open-loop gain it must be always used with negative feedback - and it is the feedback factor alone (composed of resistors and/or capacitors) that determines the closed-loop gain properties.
35,198
To be pedantic, this is not a property of the opamp.
The significant property is the very high open-loop gain (or infinite gain in an ideal op-amp).
This makes the opamp ideal for formulating an analog comparator.
The use of negative feedback is a requirement of the circuit topology if one wants to constrain the gain of the circuit.
atferrari
Joined Jan 6, 2004
5,029
Hello, I would like to know how an operational amplifier works and what it is used for, some applications, thank you very much
What is life?
How to describe the Universe?
Where the wind goes when it is not blowing?
All nice questions.
Felipito: put some effort from your side.
LvW
Joined Jun 13, 2013
2,038
OK - agreed. But notice that the questioner also has asked "what it is used for...?".
On the other hand - why is the opamp equipped with such a large open-loop gain?
Answer: Because we want that the transfer properties are determined by the feedback network only.
atferrari
Joined Jan 6, 2004
5,029
Hi Felipe, what about trying to get "Op amps for everyone" - 3rd edition - 2009 - TI by Ron Mancini / Bruce Carter?
The most reasonable introduction I've ever read. Pity I got it 20 years late.
By the way, Ron Mancini is member of this forum.
