Operational Amplifier
Thanos_husk
Joined Nov 6, 2018
12
Hi
I have the following task:
Design a circuit using only one OpAmp witch outputs a triangular waveform with a frequency of 38kHz. The power supply provides me with 20V dc only.
The only circuit i found online was using two OpAmps. One for producing a Square waveform and the second one transformed it to a triangular.
Any help would be appreciated.
Thanks a lot.
38,504
In theory you could do it with one op amp square-wave astable oscillator driving two transistor current mirrors that charge and discharge a capacitor.
But that's more complicated then using two opamps.
atferrari
Joined Jan 6, 2004
5,011
The ICL8038, IIRC, did that precisely.
My feeling is that at 38 Khz it should require little tweaking.
WBahn
Joined Mar 31, 2012
32,825
My question is where does this restriction come from? Normally it would be a restriction imposed by the homework problem, but the claim is that this isn't homework but rather part of a much bigger project. So why the restriction? Such a seemingly arbitrary constraint in a real project normally has lots of other impacts as well. Is it due to cost? Layout size? Parts availability? Each of those probably splashes over to other parts of the design.
