Hey everyone,
I have a few questions regarding op-amps and wondered if you could clarify them for me. According to the picture in the attachment, you can see that an op-amp is more or less a voltage amplifier, correct? What about current gain, how would you calculate that on an op-amp? Would the current going into the circuit be the same coming out? If you wanted to increase current, would you use a couple of transistors, which are current amps, to accomplish this?
How do you define negative and positive feedback? Would some of the output going into the non-inverting input (+) be positive feedback, and some of the output going into the inverting input (-) be negative feedback?
