OPAMP INTEGRATOR
hero22222222222
Joined Dec 22, 2019
78
Hi im currently working on a project and it requires the use of an integrator opamp to output a sawtooth wave.
However, when i feed a square wave to the input i get a square wave as an output. During simultion i get a sawtooth for the exact values i have used.
How can i solve this issue?
ci139
Joined Jul 11, 2016
2,026
sawtooth /|/|/|/|/|/|/|/|/|/|/|/|/|/|/|
sawtooth |\|\|\|\|\|\|\|\|\|\|\|\|\|\|\ // may require a high slew rate op amp such as LT1125 LT1126
triangular /\/\/\/\/\/\/\/\/\/\/\/\
?which , ?frequency , ?amplitude , ?adjustability , adjustment ?method/-control?source
hero22222222222
Joined Dec 22, 2019
78
Hi sorry i meant triangle wave. I only have access to cheap op amps. In addition, I used a 0.2uF capacitor is this too small? What value resistor and capicitor would you recommend to get an amplitude of approximately 15V?
My opamp integrator is a simple integrator (inverted pin connected to a resistor and output is connected to inverting pin using a capictor. Positive pin is connected to ground.
(I cant seem to upload the schematic on this forum )
OBW0549
Joined Mar 2, 2015
3,565
There is absolutely no way any of us can answer that question without seeing a schematic diagram of your circuit. If you can't post one, it's because you haven't reached a post count of 10 yet.
JohnInTX
Joined Jun 26, 2012
4,787
That seems to be an odd requirement.
it is odd... but that's one of the limitations placed on noobies on this site ... unfair as it is.
It’s there to keep,the spammers at bay. Most spammers don’t participate long enough to post 10 times so it keeps the full-page ads and worse from being posted. Sucks for legitimate posters but unfortunately that’s how it is set up.
TeeKay6
Joined Apr 20, 2019
573
Perhaps "somebody" could contact the T.S. via a conversation. The T.S. might be able to attach a schematic file in reply and then "somebody" could post that.
