I have a PCB with an OPA552 opamp. I have a tina model that works well.
Here is the pinout of the opamp pins.
1-4-5 > -9v
7 > + 41V
2 > through 10K ohm to ground
3 > receives 0-4 V square wave at ~.25Hz
6 > output with a 100K pull down resistor and 25K to pin 2
8 > flag through 100K ohm to ground
My anticipated output should be 1+ 25K/10K. I am running non-inverting positive input.
I get all this with Tina as I expect.
With my o-scope, I get 0V with a 1.3MHz 4v ripple with no variation over a few seconds on the output at pin6.
There is more to the story.
The -9v and + 41v are provided by a separate power source than the input signal. It is possible that the opamp could receive a signal with no power.
Also, the opamp could receive both powers with no signal. The signal and two power supplies are switched separately but the three share a common ground.
The pricey opamp is rated at +/- 30V and my limited knowledge is that they can withstand any delta power supply less than 60V.
A schematic of my circuit from tina is attached and it works in the virtual world.
I am hoping that by stating my issue and having outside reviewers look at these values, I could find out why I have no output wrt the .25 Hz signal.
Any help will be greatly appreciated. While I am waiting for a response to this posting, my diagnostics will involve looking at the voltage spikes on the PCB while the switch toggles that connects the -9 and +41v power supplies.
Thanks.
1-4-5 > -9v
7 > + 41V
Thanks.
