OP Amps
Celostrophus
Joined Jul 22, 2012
4
I'm attempting to solve this problem for Vout, but I keep getting an answer that makes no sense.
Vout = 10*L*(1/1,000Ω)*dvin(t)/dt
Any help?
I know that the gain is 10 from G = (1 + 9000Ω/1000Ω) = 10
I also know that Vout = VL(t) * G
I guess I'm just having trouble determining VL(t) correctly.
VL(t) = L * di(t)/dt
iL(t) = Vin(t) / R , R = 1000Ω
VL(t) = L * 1/R * dVin(t)/dt
But since Vin(t) is a square wave this would make so sense at the places where the slope is infinity.
You need to find the voltage wave shape at the inductor and just multiply that by 10. The voltage at the input to the amplifier will be the applied step voltage at time = 0 and then it will sag. At what rate?
That is the essence of the problem, and it's not about sine waves or the response to a sine wave.
Celostrophus
Joined Jul 22, 2012
4
So basically their are two equations that the output voltage is switching between depending upon the input voltage.
Those two equations being:
Vout(t) = 2.5e^(-t/τ) for 0 < t < 1, 2 < t < 3, ...
Vout(t) = -2.5e^(-t/τ) for 1 < t < 2, 3 < t < 4, ...
where τ = L/R = 2mH/1kΩ
I actually don't know. I'm very good with op-amps but I suck at inductors.
I can tell you that the inductor and the 1k resistor form a voltage divider. The apparent resistance of the inductor changes over time, from near infinity (because of the near zero rise time) to near zero after some time, but this frequency is so high that the inductor current never stabilizes.
That's about all I have.
t_n_k
Joined Mar 6, 2009
5,455
Your second equation is incorrect.
\(V_{in}(t)=i_LR+L\frac{di_L}{dt}\)
It turns out
\(V_L(t)=V_{in}exp^{ -\frac{R}{L}t}\)
But that's only half the story - you have to deal with a transient condition with a square wave input rather than a simple DC voltage. That requires a little more careful thinking and the analysis to match.
33,135
Here's your problem (and this is what t_n_k was focusing on). The current through a resistor is proportional to the voltage ACROSS the resistor. But Vin(t) is just the voltage on one side of the resistor. You have to subtract the voltage voltage on the other side of it in order to get the voltage across it.
