Op Amp as voltage sink - need help
Status
Not open for further replies.
MadCow4242
Joined Apr 17, 2019
18
What was the chip that blew up and what is the chip you are thinking of using now?
SG
The one I had issues with was LMC7101BYM5-TR. I'm looking at using EL5111IWTZ-T7A. Looking deeper, the original op amp doesn't look like it is rated for sinking 10V... but the new one is.
sghioto
Joined Dec 31, 2017
8,755
Specs say 35ma max, surprised that the chip could not handle that assuming a 10ma max current on the dimmer.
Before proceeding further I would measure the current draw on the dimmer.
Can you post a link to dimmer?
SG
MadCow4242
Joined Apr 17, 2019
18
SG
The "dimmer" is the board I'm building. The lights I'm driving are a series of up to 80 of these (and a newer light using the same spec interface for dimming): www.cazabon.com/temp/ESW.SPEC_.3.2018.v1
BobTPH
Joined Jun 5, 2013
11,659
The datasheet does not support your understanding of the dimming control. It is simply an input that expects a voltage of 0-10V and draws 0.15mA, as far as I can tell.
Have you tried operating a single unit from a simple 10V supply and a 1K pot? My guess is it will work just fine.
Bob
MadCow4242
Joined Apr 17, 2019
18
Bob
I agree that it doesn't line up :) That's why the first dimmer I built did exactly that. Unfortunately their data sheet doesn't match the reality of what they deliver. There are two industrial standards for 0-10V dimming - one where the dimmer provides a 0-10V source current, and one where the lights provide the current and the dimmer sinks it to get the right 0-10V voltage. They're providing the latter, despite what their spec sheet says.
A 10V supply on a POT will actually work with either version - you can source or sink current through it. So my first manual dimmer worked fine because that's all it was. When I naieve-ly built a DAC to supply 0-10V it blew up the op amp because it wasn't built to sink that voltage.
All is good though, I have two options ahead of me: my original op-amp design with a beefier op amp that can handle sinking 10V @ 65mA, as well as the PNP version above. The beefier op amp should be better because it can source or sink current as needed - so it has wider compatibility.
Thanks for the input!
Kevin.
BobTPH
Joined Jun 5, 2013
11,659
Hmmm. So how much current do you have to sink to bring the voltage to zero?
Can you point me to the current sinking control standard?
Bob
LowLight
Joined Jan 13, 2023
MadCows4242 What was your final result to this. I am trying to make the exact same thing right now, and curious what you ended up with.
Moderation
That user has not posted since 2019, please create your own new thread
Status
