Online guides for making toroidal inductors and transformers? (moot)
metermannd
Joined Oct 25, 2020
472
Looking at the one board I haven't really monkeyed around with, it has one bobbin-wound inductor, two toroidal inductors, and one toroidal transformer.
Are there any recommended online resources for "rolling your own" toroidal inductors?
When removing windings to change the inductance, how does one tell which end to start from and are turns counted from the inside or the outside?
Papabravo
Joined Feb 24, 2006
22,111
You go to the websites put up by the manufacturers of the materials. Everything you could want or need is there.
jpanhalt
Joined Jan 18, 2008
11,087
Plenty
Turns are counted by passes through the center. Period. I don't know what you mean by inside or outside.
metermannd
Joined Oct 25, 2020
472
I eventually found a later version of this circuit that uses a safer voltage level for the drive circuitry AND only requires ONE inductor - and which value is 'close nuff' to an off-the-shelf part, that I can probably subtract a few turns to adjust the inductance down a bit (alternatively, I have a few boards of this later version that can be scavenged for coils).
