I was pushing hard. I had no problem getting the solder off the first time but when I tried to clean it up better I struggled trying to heat it up.What are you doing wrong?
1) Your soldering iron is too hot. You either need a temperature controlled soldering station or you should put a light dimmer control on your iron.
2) You are using too much pressure or force on the PCB pads. Too much heat and pressure will lift the copper pads and traces off the board. In order to remove a component, add some more rosin core tin/lead solder to the joint first. This allows the joint to take up the heat better, especially if the original solder used is lead free. Once the solder is melted, use a solder sucker to suck up the solder. While the pad and leg is still hot, move the component leg around so that it breaks free from the hole.
(Also while the joint is still hot, try to straighten the component leg so that it sits vertically in the center of the hole. This will make it easier to break free from the hole and to extract the component.)
Then work on the other legs until you can lift the transistor freely from the board. If we don't want to save the component, it is easier to clip the component away from the leg, while leaving sufficient leg that you can grab with needle nose pliers.
3) You now have solder bridges between traces. This will cause shorts and sparking. Get some solder wick and clean up all around the pads and traces.
I’m using the proper iron.
does speaker wire substitute for wick.
