One seven segment display, switch controlled counter:
norbey
Joined Apr 18, 2017
Program Description: 1. Making use of MPLAB X IDE, demonstrate a numerical up counter on a seven segment display that is connected to PortD and switched on by a transistor that is controlled by port pin RC1. 2. Every time the pushbutton connected to port pin RA4 is pressed and then released the seven segment displayed numerical number increments. 3. The numerical seven segment displayed number must increment form 0 to 9 and then roll over from 9 to 0 to allow continuous incrementing. 4. First use a flowchart to determine the program structure and then generate your commented firmware source code.
WBahn
Joined Mar 31, 2012
33,122
All you are doing in all of your threads is just posting one of YOUR homework problems and giving no indication whatsoever that you have put, or have any intention of putting, any effort of your own into solving YOUR homework. It's pretty evident that you just expect strangers to work your homework for you and give you the solutions. That's not how this works.
