one of four? sequencer?
Gerry_D
Joined Nov 3, 2016
OK, guys, it's been a darn long time since I tinkered with chips, more like 20 or more years ago. I'm retired now, but I need to build a little device.
I can't get my head on straight about this and remember what chips would do it simply.
What I need is a circuit that will sequentially turn on three LEDs, for about 0.5 seconds and an off period of the same duration and then repeat.
There is one chip that would sequence, like one of ten, and a way to make it loop and limit to four, but it's just not coming to mind.
I'd prefer to use chips that I can get at Radio Shack and TTL or 54/74 series preferred.
Maybe a 555 timer as a clock.
Thanks in advance!
Gerry
EM Fields
Joined Jun 8, 2016
578
Thanks in advance!
Gerry
GopherT
Joined Nov 23, 2012
8,009
Thanks in advance!
Gerry
Most Radio Shack stores are closed now. If you have a few days, you can order from Digikey.com and select "first class mail" and your shipping/handling will be the price of one chip at Radio Shack and each chip will be about 1/4 the price of radio shack.
You need a decade counter and have the fifth pin reset the counter as EM Fields shows above.
A CD4017 is the original and now 74HC4017 or any variant thereof will meet your needs.
An NE555 or any different 555 variants will meet your needs as the pulse train.
AnalogKid
Joined Aug 1, 2013
12,300
EM - My interpretation of post #1 is that there is no off time between LEDs lighting up. Q0, Q1, and Q2 to the LEDs, skip Q3 for the off state, and tie Q4 to reset. If I'm right, there is no need for a 49.9% duty cycle from the 555; R1 can equal R2.
ak
Gerry_D
Joined Nov 3, 2016
Have a look at the posts #10 and #12 of the following thread for some ideas:
https://forum.allaboutcircuits.com/threads/leds-555s-flashers-and-light-chasers.19075/
Bertus
Great Info, Thanks, like I said it's been a long time. About 20 years ago I designed a printer adapter for the govt that simply changed a 7-bit parallel to an 8-bit parallel printer interface, (Centronics standard), the big thing was the trick to delay the timing by running it through a few 7414's to delay the sync/clock to make it work. Saved them close to 3/4 mil the first year. Most of the stuff after that was just designing, building and writing procedures for simple test fixtures that used switches to load/program the UUT. Now, after retirement from the govt, I just fix slot machines on the casino floor for a local casino.
Gerry_D
Joined Nov 3, 2016
I ordered the chips from Jamco, also some voltage regulators to power the wife's candles instead of batteries. I have about 150 wall-wart 50 mil 9V power supplies that I can use for those.
