On the search for an LTSpice equivalent Gate Drive Model for PM8834 (4 A dual low-side MOSFET driver)
Oneisall
Joined Oct 18, 2023
Hi dear ones,
Does someone know of a gate driver that would do the work on LTspice as a replacement for PM8834?
It is necessary that it has an independent enable function for each driver. Attached below you can see the features and the block diagram of PM8834
meant for a PFC application
kind regards
eetech00
Joined Jun 8, 2013
4,704
Hi dear ones,
kind regards
Try ADP3654. It doesn't have enable pins but you could probably fit some external logic to the drive logic input pins to provide that for simulation purposes.
Oneisall
Joined Oct 18, 2023
This was also considered.
There is also MAX17603 which might be implemented for the purpose
But it seems at first that there is no LTspice Models for both too.
Thank you for your response though.
