Nope only LED and C2Is there any thing connected to Q3-3 except for LED & C2 ?
Well suited for a PLC / kaadder logic. A pic or avr would do. No coding and jur GUI programming.switch -beep- 1min red led - audible beep - 7sec - 4 sec green led (red off) - back to start beep and 1min red led on
Tried this but still the sameTry connecting a 10 k R from Q1-2 to ground so that pin 2 rests at about 3 V allowing a shorter neg. pulse to set the 555.
No beeper, still not tried the beeperWhat form of beeper circuit is used ? Post # 34 beeper needs an invertor to work & re check.
Done this but red light stays on ???Skip post 67; remove D1, D 2, R 1, R 2, R 6; connect open end of C 2 to Q1-2. Connect open end of SW
thru 1 k R to Q1-2. Coupling between Q3 & Q1 should be the same as Q1 to Q2. This works on breadboard,
why diode or gate is screwing up the works I'll save for a cooler day to figure out. Is the reset at power up working ?
For beep, need to know what type of sounder you will use. A small speaker might be easier to find?
C1 and res to ground must be on for it to workSorry, C 1 was supposed to be in remove list, no longer has a purpose. Remove R between ground & Q1-2, if it is 6k7 , might be holding Q1 on = red LED always on.
It is a cheap buzzer that came with a "Workshop Component Kit Tutorial Starter Basic Element Package Set For Arduino"Need more inf. on HSDZ, does it have built-in oscillator, if so is it loud enough on 6V ? I would not pick any circuit until we knew what we were driving.
//sound buzzer briefly
BUZ_ON(); //sound buzzer briefly
tmr1_dly1s(1); //ls delay
BUZ_OFF(); //buzzer off
//red led on, 1 minute delay
LED_ON(LED_RED); //turn on red led
tmr1_dly1s(60); //delay another 60 seconds
//start with a 7-second delay
tmr1_dly1s(7);
//turn off red led
LED_OFF(LED_RED);
//and turn on green led
LED_ON(LED_GREEN);
//end with a 4 second delay
tmr1_dly1s(4);
//turn off all leds and buzzer
LED_OFF(LED_RED | LED_GREEN | LED_ORANGE);
BUZ_OFF();
