Hi everyone,
Hope you are fine. I am currently working on a project the uses esp8266 as a MCU (I am using Nodemcu module). the nodemcu is connected to OLED and DS18B20 temperature sensor. the code works fine while I am working with only those device. When i use an interruption routine in the code the hole code does not work and the OLED does not display anything.
This code works fine with arduino. However, this does not work for some reason in esp8266.
Note : after some debugging the code was noticed to stop before the interrupt statement in the void setup ().
CODE:
#define ICACHE_RAM_ATTR
// OLED LIBRARIES
//#include <Wire.h> // Only needed for Arduino 1.6.5 and earlier
#include<SH1106.h>
#include "images.h"
// TEMPERTURE SENSOR LIBRARIES
#include <OneWire.h>
#include <DallasTemperature.h>
// PID LIBRARY
#include <PID_v1.h>
// GPIO where the DS18B20 is connected to
const int oneWireBus = 12;
// OLED PINS ASSIGNMENTS
SH1106 display(0x3c, SDA, SCL); // ADDRESS, SDA, SCL
//Define Variables for PID controller
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp=510.6, Ki=1.164, Kd=4998;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(oneWireBus);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
// DEFINING LATCHING ANGLE AND INTERUPTER
int detectado =0;
int valor=0;
uint8_t INTERUPT_PIN = 14;
int TRIAC = 13;
float temperatureC = 0.0;
// INTERUPT FUNCTION DECLARATION
void ICACHE_RAM_ATTR IntCallback();
// VARIABLES TO DISCRITIZE THE TEMPERTURE READING
int ct=0;
int lt=0;
bool r=0;
// VARIABLES TO DISCRITIZE THE PID CONTROLLER
int pid_ct=0;
int pid_lt=0;
void setup() {
// Start the Serial Monitor
Serial.begin(9600);
// Start the DS18B20 sensor
sensors.begin();
// OLED PART
display.init();
display.setI2cAutoInit(true);
// SETTING INTRUPT PIN
attachInterrupt(digitalPinToInterrupt(INTERUPT_PIN), IntCallback, FALLING);
//Define 13 as output for the TRIAC pulse
pinMode(TRIAC,OUTPUT);
// SETPOINT DECLARATION
Setpoint = 30 ;
void loop() {
// LIMINTING THE LATCHING ANGLE
myPID.SetMode(AUTOMATIC);
myPID.SetOutputLimits(100,8800);
// READING TEMPERTURE (DISCRITIZED)
ct=millis();
if(ct-lt>=2000){
lt=ct;
if(r){sensors.requestTemperatures();}
else{temperatureC = sensors.getTempCByIndex(0);}
r=!r;
// PID ACTION DISCRITIZED
// LINEAR CONTROLLER
pid_ct = millis();
if(pid_ct-pid_lt>=500){
pid_lt=pid_ct;
Input = temperatureC;
myPID.Compute();
valor= 8900-Output;
// NON LINEAR CONTROLLER
if(Setpoint-temperatureC>2.5){valor=100;}
else if (temperatureC - Setpoint > 0.5 ) {valor = 8900;}
// CONTROL ACTION
if (detectado)
delayMicroseconds(valor);
digitalWrite(TRIAC,HIGH);
delayMicroseconds(100);
digitalWrite(TRIAC,LOW);
detectado=0;
// DISPLAYING READING
display.invertDisplay();
display.flipScreenVertically();
display.drawString(0, 0, "Setpoint : " + String(Setpoint)+ " ºC" );
display.drawString(0, 50, "Temperture : " + String(temperatureC)+ " ºC" );
display.display();
display.clear();
// SHOWING THE TEMPERTURE AND LATCHING ANGLE IN THE SERIAL FOR PROTOTYPING
Serial.print(temperatureC);
Serial.print("\t");
Serial.println(valor);
//INTERRUPTION FUNCTION
void IntCallback()
detectado=1;
