Old projector to a new laptop
Jeanguypataterubberboot
Joined Aug 29, 2016
19
Not sure if this is the right place to ask this. I have a Mitsubishi XL30U projector that I'm trying to connect to my HDMI laptop. The projector has a Mini D-sub 15p connector. What would I need to make this work? I tried with a VGA cable and HDMI adapter but no luck. It says "no Signal" Also, if you determine that this should work, is there a way to test the input on the projector connector so I know it works?
Thanks for the help
Pierre
dl324
Joined Mar 30, 2015
18,403
You need something that actually converts VGA (analog) to HDMI (digital) HDMI to VGA. Most converters aren't bi-directional, so make sure you get the correct one.
EDIT: corrected conversion direction.
38,573
converts VGA (analog) to HDMI (digital).
That's the wrong direction.
He needs an HDMI to VGA converter, such as this.
Alternately he could use an HDMI to Component (not composite) converter, since the projector also has component inputs.
The only likely way to test the inputs is with a known good signal.
Joined Aug 29, 2016
19
Thanks for the help guys. I have that exact same part and it doesn't work Which is why I was wondering if there might be something wrong with the projector connection.
Externet
Joined Nov 29, 2005
2,644
What is the intention? See a projection image on the laptop screen; see the laptop screen projected to a wall ?
Manufacturers have the nasty habit of omitting 'input' and 'output' labels on the HDMI jack connectors. They are probably saving ink at the expense of confusing users.
Try your HDMI port with other devices to ensure direction and if works.
Joined Aug 29, 2016
19
I have my laptop connected from the HDMI to a VGA monitor using the adapter and it works. I pull the plug out of the monitor and plug it into the projector and I get "No signal". I am starting to think there may be a wire broken in the projector.
dl324
Joined Mar 30, 2015
18,403
If the adapter/converter works with a VGA monitor, then I'd suspect a problem with the projector.
bertus
Joined Apr 5, 2008
22,954
What is the resolution of the projector?
It can be that the given resolution is to high and the projector can not handle it.
Bertus
38,573
So it does look like there's a problem with the VGA input.
If you can't find/borrow an old computer with a VGA output to test and know for sure, then you may have to consider using the component inputs instead with an HDMI to component converter, such as one of these.
