Ohm's law not being obeyed in the following circuit?
WBahn
Joined Mar 31, 2012
33,342
Tip: Current does not go "across" a component, it goes "through" a component. Similarly, voltage appear "across" components and not through them. You want to get in the habit of using the standard terminology -- it will make communicating with others much easier.
Glad you figured out your problem.
