Obsolate Power MOSFET replacement
Catriona82
Joined Feb 15, 2017
47
Hello folks, I have been using STS25NH3LL n-channel MOSFETs in the past but they are now obsolete. Can anyone suggest suitable replacement that using the same SO-8 package? In particular it needs to be high temperature (150ºC or better) and low RDSon.
They are going to be used for H-bridge control of a DC motor so they need fast switching times.
Thanks for any help I can get!
Catriona82
Joined Feb 15, 2017
47
I have but it only comes up with the same part numbers. Part of the problem is I'm not sure at this point which parameters are the most important ones other than RDson and on off switching times.
dl324
Joined Mar 30, 2015
18,524
Gate capacitance, threshold voltage, max drain current, max drain-source voltage (Vdss), max gate-source voltage (Vgss).
