Anyone have a cheaper source for the NTE2987 NMOS. Mouser wants like $7 for one.
Either that or an equivalent part???
Unerstood... There will probably be more that 3-4 LED's in parallel also.The voltage drop across the LED is bound to vary between each of the LEDs.hgmjr
The LEDs are rated 10,000 to 12,000 mcd output. Operates from 3.2 to 3.4VDC @ 20mA.Can you provide us with a part number so that we may take a look at the Vf and the current rating of the white LEDs you plan to use?
hgmjr
G | DC equivalent circuit for selective amplifier | Homework Help | 4 | |
Moset equivalent | Technical Repair | 3 | ||
TLIN (ADS) equivalent model in CADENCE VIRTUOSO | Analog & Mixed-Signal Design | 0 | ||
Transforming this circuit into thevenin equivalent | Homework Help | 14 | ||
G | nte2987 stp20n10l | General Electronics Chat | 1 |
