NTC linearization and implementation on a microcontroller
andrew74
Joined Jul 25, 2022
273
You seem to have semicolons where there should be commas. That might have been Windows trying to be "helpful".
csv files should have commas separating the variables, otherwise they should be called something else.
When you delete .hword, also delete the comma that comes after it.
Also swap the DIV/0 error for some random large number. It's the value it will read if your thermistor gets shorted to 0V.
Substituting ; with , e swap the DIV/0 error for some random large number.
Why is there // between the commas?
Ian0
Joined Aug 7, 2020
13,317
// tells the C compiler to ignore the rest of the line. That way you can just include the spreadsheet without any further editing.
Having the rest of the calculations available may be handy for fault finding, but it does no harm.
By the way, you still have Rpullup at 10k not the value you calculated.
Including the entire spreadsheet saves time if, for instance, you change your mind on the pullup value, or some outside party changes the pullup value for you, or changes the make and model of theremistor. Managers do that. . . "I thought they were equivalent, they both say 'thermistor'"
andrew74
Joined Jul 25, 2022
273
A proposito, hai ancora Rpullup a 10k non il valore che hai calcolato.
Yes, I know, I put a random value of 10k just to try. Thank you.
Now that I understand in more technical steps, I will focus for a moment on some more "theoretical" things that are still unclear to me.
1) What do these columns represent? It is not clear to me. I colored them for simplicity so we can understand each other better.
Ian0
Joined Aug 7, 2020
13,317
red = temperature in tenths of degree C: 2630 = 263.0°C
yellow = data from ADC
blue = resistance value
green = temperature in Kelvin
andrew74
Joined Jul 25, 2022
273
It is not clear to me how you constructed the lookup table, however, isn't it enough to make a table with two columns?
I mean these two: (fortunately are on the datasheet)
(there are two highlighted values but whatever, pretend they are not)
I detect the voltage on the microcontroller pin, in the code I calculate the resistance of the NTC "Rntc" (doing the inverse voltage divider formula .. since that's the circuit) ... then I compare the calculated Rntc value with those in the column on the datasheet (the table image I just attached).
As soon as I find the closest one, I take the adjacent Temperature value.
Am I wrong?
Ian0
Joined Aug 7, 2020
13,317
You're determined to keep your processor busy! Mine has 8 other analogue inputs to cope with four of which need RMS calculations. At a guess your processor can't divide on its own - do you realise how much of its time a division instruction takes? You're not making it do this in floating point, are you?
Not to mention the time it takes to do the search routine. Then all you do is take the nearest value on a 5°C scale. Not exactly precision.
I hope your program doesn't have anything else to do! Otherwise it might be late for its own funeral.
andrew74
Joined Jul 25, 2022
273
Thank you for the advice.
Then I ask you to explain how the solution you sent me (on excell and the .csv file) should be implemented in a microcontroller and the benefits you get from it, because I haven't quite get the concept yet.
35,320
If you can come up with a few ADC counts vs temperature points I can show you how to move on from there.
The math to implement on an Arduino or any MCU is simple. It does not involve using a look-up table.
Ian0
Joined Aug 7, 2020
13,317
Let's suppose the 10-bit value you read from your ADC is called ADCVAL.
The to get the temperature
Code:
Temperature=celsius10k[ADCVAL>>2];
and that's it.
>>2 because you just want 8 bits to access the 256 entries in the table.
Ian0
Joined Aug 7, 2020
13,317
Now, it would be a shame to let those last two bits of precision go to waste, and a pain or a waste of memory to use a longer table.
so:
Code:
Temperature_ff+=ADCVAL;
Temperature_iir-=(Temperature_iir>>8);
Temperature_iir+=(celsius10k[temperature_ff>>2]);
Temperature_ff&=3;
Temperature=Temperature_iir>>8;
It feeds forward the unused least significant bits. If the least-significant bits were 0b11, then three times out of four it would read the value from the table one position higher.
Lines 2 and 3 make an IIR filter which averages the data.
Line 5 gives the real temperature to a greater degree of precision.
ericgibbs
Joined Jan 29, 2010
21,651
hi andrew,
I often use the same method as described in your post #25, it works OK.
You need to ensure that the therm values etc are the thermistor type you use.
E
C-like:
/* thermistor temperature profile 12/05/2023 ESP57
Vadc = 5.0* (Rt / (Rt + 10000))
ADCout = (Vadc /5.0) * 1024
#define ADCin1    0// pin
float R0 = 10000;  // Therm resistance at 25C
float Bval= 3370;  // Therm Beta value
float Rth = 0;
float ADCcnt= 0;
float Rser = 10000; // Series resistor with Therm
float ADCvolt = 0;
float Vss =5.0; //  ref Volts
float TambAvg =0;
float Tref = 298.15; // 25C
float Tamb = 298.15; // 25C
int i =0;
int avg=0;
void setup()
  Serial.begin(115200);
  Serial.println("NTC1");
void loop() {
for (i = 0; i<= 99; i++){
// get ADC count for the ADC inp voltage
  ADCcnt= analogRead(ADCin1);
// Calc ADC input voltage
  ADCvolt = Vss*(ADCcnt/1024);
// Calc Therm resistance that will give ADCvolt
  Rth= (ADCvolt*Rser)/(Vss-ADCvolt);
//Transposed Equation for Tamb, Therm Temperature
  Tamb =(Tref*Bval)/((Tref * log(Rth/R0)+Bval));
  Serial.print("ADCcnt=");
  Serial.print(ADCcnt,0);
  Serial.print("  ADCvolt=");
  Serial.print(ADCvolt,4);
  Serial.print("  Rth=");
  Serial.print(Rth);
  Serial.print("  Cdeg=");
  Serial.println((Tamb-273.15),3);
  TambAvg=TambAvg + Tamb;
  avg=avg+1;
// take 100 samples and average
  if (avg >= 99){
  Serial.print ("   TambAvg=");
  Serial.println((TambAvg/avg)-273.15);
  TambAvg=0;
  avg=0;
  delay(100);}
andrew74
Joined Jul 25, 2022
273
hi andrew,
E
C-like:
float Rth = 0;
float ADCcnt= 0;
float ADCvolt = 0;
float TambAvg =0;
int i =0;
int avg=0;
void setup()
void loop() {
  Serial.print(Rth);
  avg=avg+1;
  if (avg >= 99){
  TambAvg=0;
  avg=0;
  delay(100);}
Thank you for the code.
However, I wonder where in your code is the table that I attached in my post #25 ... I can't see it.
Why didn't you reverse the voltage divider formula here to find Rth?
Or maybe you did but I don't see it explicitly
ericgibbs
Joined Jan 29, 2010
21,651
So, given my NTC with R0=10k at T0=25°C and beta=3977 (written on the datasheet, I don't need the online calculator but thanks anyway) and working in a range of thermperature=[25 ... 43]°C --> Tavg=34°C
hi andrew,
Reading the above, how can your Therm have a resistance of 2200R at 25C.???
Which thermistor are you using.?
E
andrew74
Joined Jul 25, 2022
273
hi andrew,
E
View attachment 296257View attachment 296258
No no as I had already specified you don't have to consider that yellow highlighter because it was left on the PDF file in which I took the screenshot.
The NTC that I am using has 10k at 25°C. It is this:
andrew74
Joined Jul 25, 2022
273
You need a look-up table to get the temperature.
Input the value of B and your pullup resistor, and the resistance at 25°C. The outputs are in tenths of a degree.
Don't forget that most thermistors have quite a wide tolerance, and ±4°C might be good for an uncalibrated one.
If you have a better than 8-bit ADC, and want better accuracy, you can use a feedforward technique, or a bigger lookup table.
As I also asked @ericgibbs .. It is not clear to me in your excell how "Resistance" was found ... why didn't you reverse the voltage divider formula here to find Rth?
In your excell if I'm not mistaken you calculated Rntc=Rpullup/(256/ADC-1)
Vout=Vntc=Vs*Rntc/(Rntc+R1) --> Rntc=.. reverse formula and you get a something like Rntc=Vntc/Vs....
ericgibbs
Joined Jan 29, 2010
21,651
hi andrew,
I am using this RED block of values.
I am finding Rth in order to determine the Temperature
Calculated value print out
E
andrew74
Joined Jul 25, 2022
273
hi andrew,
E
View attachment 296264View attachment 296265View attachment 296265View attachment 296263View attachment 296264
I understood your code, however it seems to me that your solution is very different and less complex than the one adopted by @Ian0
Am I wrong? They seem to me to be two different solutions.
I'm asking so that I can tell if you're talking about the same thing or not, otherwise I'm confusing
ericgibbs
Joined Jan 29, 2010
21,651
hi andrew,
I consider using the manufacturer's Rth versus Temperature is the best approach to use.
Both methods rely on the accuracy of the ADC converter.
Why don't you as an exercise run both methods and compare your results, they would be helpful to other readers.
E
Ian0
Joined Aug 7, 2020
13,317
81E93A33-6133-424B-B89F-DD9F62A48084.jpeg@ericgibbs ‘s code is massively more complex than mine. He has a microcontroller calculating logarithms!
