NSD618 TO220 case datasheet please
punkieys17
Joined Oct 4, 2014
18
I have a Hantek oscilloscope with a power supply problem. The first major semi is marked NSD618 B2045G ON AKA. The ON is in a circle and I believe is thus ON Semiconductors that was purchased by Texas Instruments. Any help in fiding a datasheet...and thus a repalcement is needed would be gratefully appreciated.
Irving
Joined Jan 30, 2016
5,107
No PDF datasheet but found this info:
NSD6180 Datasheet, Equivalent, Cross Reference Search
Type Designator: NSD6180
Material of Transistor: Si
Polarity: PNP
Maximum Collector Power Dissipation (Pc): 10 W
Maximum Collector-Base Voltage |Vcb|: 100 V
Maximum Collector-Emitter Voltage |Vce|: 75 V
Maximum Emitter-Base Voltage |Veb|: 5 V
Maximum Collector Current |Ic max|: 2 A
Max. Operating Junction Temperature (Tj): 150 °C
Transition Frequency (ft): 50 MHz
Collector Capacitance (Cc): 30 pF
Forward Current Transfer Ratio (hFE), MIN: 40
Noise Figure, dB: -
Package: TO202
Possible alternatives: 2SA1593
