i need help with designing a circuit for switching from NPN to PNP or vice versa using single circu
R Thread Starter radiumtron Joined Jan 28, 2018 1 Jan 28, 2018 #1 i need help with designing a circuit for switching from NPN to PNP or vice versa using single circu
Alec_t Joined Sep 17, 2013 15,156 Jan 28, 2018 #2 Welcome to AAC! Sorry, but your question makes no technical sense. An NPN transistor can't be converted to a PNP one, or vice versa. Exactly what are you trying to do and why?
BobTPH Joined Jun 5, 2013 11,654 Jan 28, 2018 #3 What is the problem you are tying to solve by switching between and NPN and PNP transistor? Bob
GopherT Joined Nov 23, 2012 8,009 Jan 28, 2018 #4 radiumtron said: i need help with designing a circuit for switching from NPN to PNP or vice versa using single circu Click to expand... Here is the typical PNP-as-a-switch (also known as High Side switching. NPN shown with Low Side Switching. What are you trying to do?
MrChips Joined Oct 2, 2009 35,185 Jan 28, 2018 #5 Reverse the polarity of the power supply or battery when substituting a PNP transistor. (I'm not sure I understand the question.)
T Tonyr1084 Joined Sep 24, 2015 9,744 Jan 28, 2018 #7 Either that or he doesn't know how to get back to this thread.
