Pardon if this isn't in the correct forum, and please move if so.
When I'm not at my 9-5, I dabble in music, and have restored vintage amplifiers and completed several effects builds, both from scratch and from kits. So, a friend asked for my help to see why a commercial pedal of his wasn't providing increased signal gain as it is designed to. I have bit of experience with this circuit, having built a clone of the pedal that this is also a clone of (Klon Centaur for reference).
Where I'm having issues is on the TC7660s charge pump. In this circuit it's supposed to take the DC 9V in and provide 18V out on pin 8 to the op-amps, but I'm not measuring 18V at pin 8, just the same 9.37 as from the power supply. This is when I measure it from ground at the power supply plug socket to pin 8; interestingly, measuring it from pin 3 (IC ground) to 8 gives me about 0.3v.
I've swapped in different IC's from my own parts box and am having the same issue on all.
I've never bumped into this issue before on any of my own kits or scratch builds, so I'm not completely sure where I should focus my troubleshooting efforts. Any advice or pointers you may have would be greatly appreciated. Thanks.
