Not gate troubleshooting 74LS06N
holz1100
Joined Apr 27, 2016
18
I am having troubles with the 74LS06N not gate.
An input of 5v gives an output of 0.05v (correct).
However, an input of 0.128v gives an output of 1.350v (not high enough)
I am powering the gate with 5v. Any advice on troubleshooting?
holz1100
Joined Apr 27, 2016
18
As @bertus mentioned, that device needs a pull-up resistor. The value depends on what the output is driving.
The output is just fed into another logic gate (an AND gate). Any help in the way of how to calculate the pull up resistance value if i'm feeding into another and gate?
The switch by the not gate represents the input being either high or low
dl324
Joined Mar 30, 2015
18,333
upload_2016-5-8_7-37-29.pngAssuming the AND gate is 74LS08, the maximum high level input current is 0.1mA and the minimum high level input voltage is 2V. The largest pull-up you can use is R = V/I = 3V/0.1mA = 30KΩ, but you could only drive 1 LS TTL load. LS gates have a fanout of 20, so I'd use nothing larger than 1.5KΩ.
hp1729
Joined Nov 23, 2015
2,304
You need a pullup resistor on the output of the NOT gate to +V. 1K to 10K. The voltage you are reporting (1.35 or whatever it was) is the floating input of the next gate.
