Nordic Track control board issues (MC2100ELS 50-2Y)
ep007
Joined Jan 19, 2024
Hi, I have a Nordic track treadmill control board (MC2100ELS50-2Y), it's running the motor, but sometimes it's slowing down a bit, but then running ok again for awhile. Then when I stop the treadmill from the console, the motor starts again and stops. This happens every 30 seconds. I disconnected everything except the power to the board, I can see the red LED blinks every 30 seconds. Anyone have any idea?
ep007
Joined Jan 19, 2024
No there is no overload, the motor are not connected, when I put my ear close to the control board, I can hear a high frequency sound, not sure what that is. But th red LED is turning off for a split second every 30 seconds. I don't think that is normal.
MaxHeadRoom
Joined Jul 18, 2013
30,808
It is normal to be on Constant, until it receives a command and then it should be a slow pulse rate.
The best way to trouble shoot these boards is stand-alone on the bench, as the other processor in the Op panel can confuse things.
But you need the 20Hz PWM signal into HD2 pin 4.
MaxHeadRoom
Joined Jul 18, 2013
30,808
There are cheap signal generator units out there that work,
I built some small controller boards awhile ago that have the stop/start PB inputs on also.
