Nonzero level detector question
madnessguy
Joined Apr 2, 2024
Using the Voltage Divider, not the reference voltage of 0V, we intend to configure the Voltage Comparator with the reference voltage desired by the user. Based on the reference voltage, it is intended to output Low when the input voltage is higher than the reference voltage, and High when the input voltage is lower than the reference voltage. High and Low are determined as follows.
Mintypicalmax
High4V5V6V
Low-1V0V1V
In this case, I wonder why we should use LM358 instead of TL084.
ericgibbs
Joined Jan 29, 2010
21,503
Hi May.
Welcome to AAC.
Interesting problem.
I assume you have the OPA powered by dual supplies?
Do you have a basic circuit idea you could post?
E
WBahn
Joined Mar 31, 2012
33,016
Mintypicalmax
High4V5V6V
Low-1V0V1V
Who is telling you that you should use the LM358 instead of the TL084?
Have you looked at the data sheets for both parts to see what is different between them and considered how those differences might or might not be relevant to your application?
What is your opamp being powered by (what are the supply voltages)?
Why are you using an opamp instead of a comparator in the first place?
Have you considered what might happen if the input is very close to the reference voltage such as noise keeps moving it back and forth above and below the reference voltage? Is that behavior acceptable? If not, what might you do about it?
Audioguru again
Joined Oct 21, 2019
6,826
The IC amplifiers are completely different.
1) The minimum recommended supply for the LM358 is 3V and its "input common-mode voltage range" is 0V to V+ minus 1.5V.
2) The minimum recommended supply for the TL084 is +5V and -5V. Its "input common-mode voltage range" is Vcc- plus 4V to Vcc+.
