Ok I understand. So potential energy is a "potential" to possess energy and not of some defined energy nature itself. I agree. I think again our confusion was word choice. Stored energy v/s released energy.Ok, so you boost something out of the earth's gravitational field, where it will never return. Is that potential energy? A potential is just that, something that could be, but isn't.
Can I conclude that you agree with me then? I still think that the equation doesn't explicitly tell you which one causes the other. Writing F=ma is simply easier.Re arrange F=ma to
a=F/m to get the idea.
Acceleration is caused by a force but a forced is not caused by acceleration because to cause acceleration you need force.
Nearly there, potential is real energy. If you would like to confirm this the (TV) engineer's way charge a 1microfarad capacitor to 440 volts potential and then grab hold of it.Stored energy
E=MC^2. With expectant mothers, we won't need fossil fuel! Especially not if we can keep n>1.Although we don't see the outcome of this, the energy goes towards increasing the mass of the baby,
LOL That's funny!E=MC^2. With expectant mothers, we won't need fossil fuel! Especially not if we can keep n>1.
I think that the terminology "potential energy" might be misleading to some who might think that the energy itself is potential; i.e., doesn't really exist for some reason. It might be better to think of "potential" in the sense that this energy has the potential to do work.Nearly there, potential is real energy. If you would like to confirm this the (TV) engineer's way charge a 1microfarad capacitor to 440 volts potential and then grab hold of it.
I'd say its potential energy (=stored energy) is real.
By the way if you want answers look at this thread
http://forum.allaboutcircuits.com/showthread.php?t=23728
I started it for this very reason. Your interpretation is closer than most.
is the key phrase here. For something to gain potential energy you have to input energy, so the stored energy concept is a good way to look at it.charge a 1microfarad capacitor
What rule changes? Zero as a numeral has been around for maybe a thousand years, thanks to the mathematically literate folks in India, and the concept of different bases in numbering systems has been around for many thousands of years. George Boole worked out a system of logic bearing his name that fit very nicely with diode or transistor voltages that could be in either of two states: high or low. Using this logic and a base-2 numbering system, and you have the data in a computer. At some level, all computer programs, data, images, and so on are nothing more than long strings of zeros and ones.Rule changes to accomadate 1 and zero were made for computer
langage so systems would work.Who going to make the next rule
change. No one can predict change,like your credit card.They said we reserve
the right to change "all terms may change for any ....reason. They did away
with all the fine print and fuzzy math.You will spend a lot energy to keep from
flat lining in real life.This contain math,energy and a formula for change and potenial.
Thanks -Have a nice day.-Loosewire
OK. Keep in mind, though, that Boole's work on logic dates back to about the middle of the 19th century, predating electronic computers by a century. Furthermore, computers preceded computer languages, in that the first computers were programmed by hard-wiring connections between components, and later by setting front-panel switches. Sometime after this, John von Neuman made the realization that strings of binary digits could serve as both data and instructions to a computer, which brings us to the era of programming computers by machine code instructions.You are right on it, Boole was what I was referring to.
Actually, much was accomplished, but whenever someone tried to decide if they should publish a result, the decision was based on fuzzy math and the answer never perfectly equated to a "yes" value.There was a lot of talk about fuzzy math 20 years ago or so, but as far as I know, nothing much came of it.
by Jake Hertz
by Aaron Carman
by Duane Benson
by Duane Benson
