I'm trying to create a circuit to sense when an ac current rises above approximately 500 milliamp and have a load switched on. Should be very simple I would think except I have no experience with these sensors. I assume the sensor will provide a current which will need to be converted to a voltage and I could use the voltage to bias a mosfet. So the current would probably need to be converted to DC and there may need to be some kind of amplification and something to limit the voltage if the current is too high. Are there any circuit diagrams that show this with how to calculate values of components needed?
