Noise reduction in a low voltage 24bit adc
Papabravo
Joined Feb 24, 2006
22,113
I apolozie for this, is there any nicer way in order to better this layout? Since I am still experimenting with component I kept my circuit to breadboard level for ease of changing anything.
No need to apologize, you're the one with the problem. In RF development we use Manhattan style "dead-bug" construction similar to what was mentioned by @crutschow in post #15. The reason is that RF circuits just won't work at all if we used solderless breadboards like you did. It is appropriate for some things, but as you have discovered, not for what you are trying to do. In RF development it is not uncommon to have a wastebasket full of discarded breadboards. Our technicians were very efficient at building new ones in short order.
ericgibbs
Joined Jan 29, 2010
21,637
hi Hiril,
If you plan a multi module project, it is wiser and less painful to build and test one module.
Using this method, you should have a reference/datum point for completing/testing the remainder of the modules for the project.
Build a single model using good construction techniques that represent the final overall build.
Post your single model results.
E
@Hiril Patel Viel Glück mit dem Projekt
Hiril Patel
Joined Dec 25, 2021
31
Wow, i have never seen such way of design before but definitly will be more compact then mine. Will research more on this nad see how can I apply for my cirucit. thank you.
Hiril Patel
Joined Dec 25, 2021
31
hi Hiril,
E
Ok, I will get to the lab tommorw and post single module results. Is it fine If I do these on breadboard? since I am using single components here
ericgibbs
Joined Jan 29, 2010
21,637
Hi Hiral,
For this type of low noise design, I would not recommend using bread board construction.
You could try using Vero type copper strip board 0.1 inch hole pitch and soldered components.
E
35,291
You will not make any improvements with solderless breadboards.
For best results you need to move forward and assemble all your circuits on double sided copper clad boards.
Pay attention to wiring, ground planes, and power supply decoupling.
35,291
And another thing. Use separate feed lines of power to analog and digital circuits.
Use LC or RC filters on analog supply rails.
Use separate ground planes for analog and digital circuits.
