Hi all,
Is there a general frequency range for the noise generated by components?
Let's say that I have a circuit which process signals at frequencies lower than 400Hz. The output must contain the least possible noise.
The best option is to use now-noise components, but unfortunately that is not always possible to find with specified requirements.
Can the noise generated by the processing components be safely attenuated using a low-pass filter?
