Any help would be appreciated!
I have no power to my treadmill after adjusting the belt with the treadmill powered on and accidentally touching the control board with the Allen key. I have attached pictures of the contact point. There is a small black mark where contact was made but otherwise no other scorch markings.
I brought the board to a local electronics repair shop and he believes that there is a fuse that may be causing the issue - small white rectangular object which I’ve also attached a picture of.
The repairman did not know what type or size of fuse this was and told me to look into it. He said he could replace it with something else which he thinks would work but from my online searching it looks to be a gas discharge type fuse??!
So, any advice as to whether this fuse would be the cause of the no power and should I get a like replacement fuse or let the gentleman repair it how he said he would if it were his own.
Thanks,
Luke
![IMG_5937.jpeg IMG_5937.jpeg](https://forum.allaboutcircuits.com/data/attachments/312/312629-1dce194e01e193e81d3a4248b9f241f4.jpg)
![IMG_5940.jpeg IMG_5940.jpeg](https://forum.allaboutcircuits.com/data/attachments/312/312627-fc6a342b69edddd633eab3af77f8e844.jpg)
![IMG_5941.jpeg IMG_5941.jpeg](https://forum.allaboutcircuits.com/data/attachments/312/312628-241856875507ce114c78aaec38a4a3db.jpg)
Thanks,
Luke
