No current limiter needed for 74XX chip input. Correct?
Mike C
Joined Feb 11, 2015
6
I just wanted to confirm that I don't need a current limiting resistor on the input of a 74XX chip.
I am currently testing on a 7404 and it seems to work fine if I connect up one of the inputs directly to the +5V power supply. Just wanted to make sure I am not risking burning out the chip. From what I can tell from reading the datasheets they have lots of internal resistors inside of them.
Thanks and sorry if this is a complete newbie question.
I have seen conflicting answers on the web.
38,512
As long as the input voltage is between 0V and the supply voltage there is no need for a resistor.
I know sometimes a resistor is recommended if the input is permanently tied high to protect the input from any transients spikes on the supply voltage but I think the chances of that damaging the input are small.
Mike C
Joined Feb 11, 2015
6
Thanks for the response.
I only have 1 voltage source (i.e. I use the same rail to power the IC and to supply the HI inputs to the ic) so I guess I am ok in that case?
Thanks a ton
