Its at vout in the post #1 imageWhere is node 002?
But if Nmos is closed then inductor shunts to ground and then their should be no voltage. However NMOS is not closing it seems? How to close the Nmos?The voltage is developing across D1 and R1 on a current path independent of the NMOS.
You are testing at DC not AC. The inductor has almost 0 ohms of resistance. Massive amounts of current is flowing.But if Nmos is closed then inductor shunts to ground and then their should be no voltage.
Replace the inductor with a 1 ohm resistor.But if Nmos is closed then inductor shunts to ground and then their should be no voltage. However NMOS is not closing it seems? How to close the Nmos?
NMOS as a switch design | Power Electronics | 2 | |
| T | Could use some help reversing an NMOS chip form the 1980's. | IC Design | 8 |
