I'm designing a little NiMH Charger, based on a Ti chip BQ2002.
The schematic below is from the DV2002L2/TL2 Datasheet.
Can anyone tell me what the purpose of R15 in this schematic is? To me it looks like if the charger is left connected to the power, even after the IC has ended charging current will continue to flow into the batteries through R15. Even if it is only 5-10 mA.
Also, if it isnt obviously implied by the answer to question above, what happens if I omit R15?
