Since a vehicles suspension has more travel in jounce(upward movement) than in rebound(downward) movement, what do you do about the potholes? Build a portable paving device to mount on your car? Potholes hurt cars way more than ice chunks ever will.Have you seriously never driven over a rock hard ice chunk that has fallen off of your car? I can garentee doing that is in no way good for your car unless that is you drive a truck.
I'm in the 'Million Mile' club as in having driven over a million miles in my lifetime now so yes I have driven over solid rock hard ice chunks with my vehicles. Several of the cars I have owned had less than 4 inches of ground clearance and it still was not something I ever saw as a problem.Have you seriously never driven over a rock hard ice chunk that has fallen off of your car? I can garentee doing that is in no way good for your car unless that is you drive a truck.
My car is completley fine the main reason for this is the garage floor being cleaner. Its the same novelty as having a heated rear windsheild because you can always scrape it off before you drive (just like you can always kick them off manually) The reason im fixated on this is because i have no knowledge in electronics and what better way to learn is there than experimentingI'm in the 'Million Mile' club as in having driven over a million miles in my lifetime now so yes I have driven over solid rock hard ice chunks with my vehicles. Several of the cars I have owned had less than 4 inches of ground clearance and it still was not something I ever saw as a problem.
To be honest I have even hit the big ice blocks that have fallen off of semi trucks while going at highway speeds too. It's a non issue unless you have a really crappy car. .![]()
