LEDs do not light. Battery does not charge. Connected battery to another power supply and it chargedWhat happenes when you put the batteries on charge, voltages, led colours?
So it could be the resistor?Looks like an Hltek Microcontroller on the trackside...also a Brown solder mark near the Hltek chip probably a resistor.
Checked the main cap which is visible in the pic, it is 400V, 100 MicroF. it shows infinite R, so no short there.That's a switchmode type psu, it could be a regulator Tl431 or caps gone faulty..
Have you got a dvm to check out the supplies, are you familiar with switchmode types?
Take pics of the trackside and a better picture of the inside.
B | 18 v Nicad battery | General Electronics Chat | 3 | |
B | NiCad Battery charger | Power Electronics | 9 | |
P | NiCad Battery versus Leaving Trickle Charger Connected Constantly | General Electronics Chat | 4 | |
W | Craftsman nicad battery charger | Technical Repair | 12 | |
S | 3.6V NiCad battery charger with auto cut off | Power Electronics | 5 |
