NFA to DFA conversion
WBahn
Joined Mar 31, 2012
33,316
The first thing you need is an NFA that actually recognizes the language you are working with.
Does your NFA accept "baa"? Should it?
WBahn
Joined Mar 31, 2012
33,316
Do we have to guess what the start state is?
Assuming it's the one in the upper left, does it accept the string "a"?
How hard is it to try out a handful of simple strings when you design a machine?
What purpose does the lower path to the accept state serve? What string does it accept that the upper path doesn't?
zulfi100
Joined Jun 7, 2012
656
Right. q0 is the initial state and q4 is the final state. Actually when I was trying to convert NFA to DFA , I was getting problems so I have to do that. But at this point if I make q4 as the final state then DFA can accept 'a' also. So lower part can help to accept string 'a'.
Is it okay?
Zulfi.
WBahn
Joined Mar 31, 2012
33,316
Is it okay?
Zulfi.
Do you mean that q0 was the start state and q1 was the original accept state and now you are making q4 an accept state as well?
It looks like it accepts the desired language now, although it is certainly a mess with paths that I'm pretty sure don't do what you think they do. But it is an NFA that appears to accept that language, so you can work with it.
